Passing wires through firewall...?
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
So I got my 84 z28 and all the wiring on the car was done sloppy I wanted to know if there was already a factory hole to get through the firewall and if not where exactly would be a good place to make one?thanks!
PIKS would be awesome, would help me out alot!
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: Passing wires through firewall...?
Here is a bare firewall....not much in the way of extra holes.
Car: 1984 Z28
dam...u aint kidding no holes guess ima have to make some myself...thanks for the piks..
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
Just buy some rubber grommets to suit the thickness of your wires and then drilll a hole.
Make sure the hole is well clear of the pedals.
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
There may or may not be a hole down where the engine wiring harness runs through the bulkhead. Both my 87 and 88 have this hole, however. Not sure if it's used for a speedo cable or not, though, since my 87 didn't have one and the 88 never got its cable reinstalled. The hole is about 3/4" in diameter.
Car: 1988 GTA Trans Am
Engine: HSR 350
I ran my 12 gauge wire through a hole right behind the driver side inner fender through the firewall. It was big enough for the wire no problems and from there I ran the wire down the plastic piece of the door jam all the way through the side of the car and it comes out where my box is.
All the other wires from the deck run inside my center console out the back of it under the seat and then runs the same route from the back seats to the sub as the 12 gauge wire
But I do have a GTA dont know if that changes anything with the firewalls?
Hope this helps...
Hope this helps...
Engine: 2.7L V6
Axle/Gears: 4.41
You should be running the RCAs down the passenger's side under the sill plate (with the rest of the rear speaker wiring)... That amp power wire and fuel pump wiring could cause interference in the RCA line.
Engine: HSR 350
And as far as pics I have none at the moment tomorrow ill be able to take a pic if you like.
Engine: HSR 350
So heres the pics.
Its the same hole that the hood release goes through. Big enough for the 12 gauge wire and my harness coming from the horn of my viper alarm system and the hood release. Oh and I know no grommets were used a bad no no lol
Transmission: 5-speed/T-5
I've been installing Car audio for about 2 decades (professionally and as a hobby), and noise only seemed to be a problem for about the first 10 years of installing, after that, noise rejection of the components, cables and improved signal strength have made unwanted noise almost a thing of the past. I've even gone so far as to run RCAs beside the power wires without any extra induced noise, not that I would recommend doing that, but I have experimented with cable routing.
I find that most noise problems come from the power supply itself, being a noisy alternator, and/or poor grounds.
As far as getting through the firewall, you will need to drill a hole, if one hasn't already been drilled. IIRC, I would drill a hole near the brake or clutch pedal, and as high as possible. Just check on both sides before drilling to make sure you won't be drilling into anything important.
Car: 1988 pontiac trans am
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
There is also a hole on the passenger side body behind the fender where the antenna wire runs through, thats what I used. Its right above where the motor harness runs in
Car: 1983 Crossfire Recaro T/A
Engine: 5.0L Crossfire
Transmission: Upgraded 700R4
Axle/Gears: 3:23
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Same here as when I did the LS swap I had a huge hole so I cut a plate for there and ran my stereo wire thru it.
Calgutie Do you have cruise control in your car as you can use that area as well and its really close to the frame rail so the wires with sit nice when you run them
Engine: HSR 350
Guess it depends on which side your battery is on lol mine was on the driver side so I found a hole over there but apparently rheres holes on both sides. So no matter what you should be able to run it cleanly either way. Lets us no how you ran it when you clean it up lol
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Get yourself a set of these and drill away!!!!!!!!
http://www.clipsandfasteners.com/125...t_p/atd362.htm
