Change your alarms LED into 12v relay for 12v LEDs
Old Jan 20, 2013 | 07:34 PM
basshead208's Avatar
Car: 86 IROC Z28
Axle/Gears: posi 4 disc 2.73
For a year I've been looking for a way to make my alarms LED power bigger stronger LEDs. Most alarms LEDs are small or dim and under powered for anything bigger or brighter. So after trial and error I found a micro 12v relay that requires minimal voltage and current to trigger the coil and switch 12v at a couple amps. Enough to power most any 12v LED or strip. I replaced my LED with the relay and power two 12v 6 packs up on the dash now, super bright and noticable. I even have left it armed as long as a week due to snow and it didn't drain the battery. And just to be abnoxios, there's a switch i can throw to a standard 12v relay and flash my LED underglow.
You can find this relay at DigiKey.com part #374-1113-ND
Its as big as your pinky nail and you have to solder leads to it.
Old Jan 20, 2013 | 07:45 PM
calgutie's Avatar
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
Re: Change your alarms LED into 12v relay for 12v LEDs
dang man thats pretty sick...LOL....never taught about that..
89GTAOz
May 16, 2020 09:31 AM
GTAman
Mar 15, 2019 11:40 AM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Dialed_In
Aug 20, 2015 01:45 PM
Fronzizzle
Aug 19, 2015 01:36 PM
