Where to put Amp?
Old Jan 26, 2013 | 12:13 PM
blazeryan's Avatar
Car: 1988 GTA
Engine: 5.0 ?
Where to put Amp?
Hi, I recently purchased a box with 2 twelves that fits down into the well in the hatch. I love the way it looks but would prefer to have the amp under the speaker box in the well. I don't want the amp showing. The place I bought the speaker box from said that the amp will over heat in the well because it wont have enough ventilation. I wanted to get some other opinions on this and see if everyone agrees? Thanks Ryan
http://www.flickr.com/photos/ryanbla...in/photostream
http://www.flickr.com/photos/ryanbla...n/photostream/
Old Jan 26, 2013 | 12:41 PM
dads old blue 9's Avatar
Car: 1990 z28
Engine: 5.0
Transmission: t-5 wc
Axle/Gears: 4th gen 3.42 posi
Re: Where to put Amp?
put the amp inside the speaker box and drill 2 3'' holes in the box one on each side down low put a fan in one hole blowing outwards mt the fan inside the box as well . kinda like a computer cooling fan ,but has to run on DC
Old Jan 27, 2013 | 06:10 AM
Andre#4's Avatar
Car: tta drophead coupe, 91 form 1LE
Engine: lc2, lb9
Transmission: 2004r, mm5
Axle/Gears: 3.27, 3.45
I put mine in the rear glove box in the trunk. I did not want anything visible or taking up trunk space. It is a Alpine PDX-V9, which is 100x4 plus another 500x1, I think. It is particularly nice because that amp is totally connected with plug in connectors, so it is easy to take out and put in if necessary. In other words, the speaker wires, power wires etc are all dis-connectable plugs. Once the wires were run into that glove box, the amp was installed in 2 minutes. It just sits in there. No screws.
I did end up with a small 8" sub in a box on the trunk floor, which I can remove and leave home if I need the room since nothing is attached to it but the speaker wires. Surprisingly, that 8" sub, which is a jl audio 8w3v3, can make so much bass that it will disassemble the interior if I play it too loud. This is in a tiny sealed $40 box. So, because I don't want to have to put loctite on every screw in my car, I can't play it anywhere near its capability. Even more remarkable because the 5 channel alpine amp is also very small. about 2x8x10 inches. There is room for 6 of them in that glove box. But you are only supposed to stack 3 of them, and if I did that I'd probably put a fan in there. But with one amp, it does not get hot.
Old Jan 27, 2013 | 03:02 PM
blazeryan's Avatar
Car: 1988 GTA
Engine: 5.0 ?
Thanks for the info guys!
Old Feb 5, 2013 | 11:10 AM
matt smash's Avatar
Car: 1987 Camaro Iroc-z
Engine: 383
can you tell me where you got those from or send me a link. I want to put some bass In my 88 iroc
Old Feb 5, 2013 | 12:48 PM
KuroNeko's Avatar
Car: 1986 Firebird, 1992 camaro
Engine: 79' 350, 89 305
Transmission: TH400, 700r4
my amp is under my box
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Car Audio
Sep 8, 2015 08:20 PM
SPEEDY Z28
Aug 17, 2015 01:46 PM
ZsTransAm
Aug 11, 2015 07:30 PM
