adding a power antenna to a non power antenna car
Old Mar 27, 2013 | 05:11 PM
kitt23's Avatar
did anyone ever buy a power antenna to install in their thirdgen? where did you buy it? my car currently does not have a power antenna....is stock better then aftermarket? or other way around?
Old May 8, 2013 | 11:52 PM
Fordvette's Avatar
Car: 1985 Camaro Sport coupe project
Engine: 2.8 mild cam
Transmission: T$ V6 5speed manual 4.04 first
Axle/Gears: 3.42 Limited Slip
Re: adding a power antenna to a non power antenna car
I found a power attenna out of another third gen at the wrecker.. Took the attenna and power relay. Easy install to wire, power wire from fuse panel, Ignition power, and one from the radio. Factor gm radio has a power wire, Pink I think, or aftermarket, just tie into the amp turn on wire for most systems
BRoss99
Aug 10, 2025 05:08 PM
colton_carlson
Mar 8, 2019 12:21 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
jharrison5
Aug 19, 2015 05:53 PM
mizz0313
Aug 12, 2015 06:45 AM
