Tweeters in A-pillars
Old Apr 30, 2013 | 01:01 PM
83 Crossfire TA's Avatar
I've heard of a few mentions of mounting tweeters in the A-pillars facing each other across the dash as the next best way to get a decent sound stage in these cars without resulting to speakers in the kick pannels...
Does this work?
Anyone try it?
Anyone have a recommendation for a small, easily mounted tweeter that is warm sounding (I don't like harsh, I'm getting older than some of you but I haven't lost enough of my hearing to like some of the more crisp sounding stuff out there)?
Old May 2, 2013 | 05:44 PM
soul.justice's Avatar
Car: 1985 Firebird Trans Am
Engine: 305 4bbl
Axle/Gears: 3.08
Re: Tweeters in A-pillars
Does this work?
Anyone try it?
If you want a good front sound stage (I will assume your interior speakers are amped and good quality) I would recommend a setup where you have 3.5" or 4" speakers in your dash and properly mounted silk dome tweeters since you are aiming for a more natural, warm sound. These will need to tie into a crossover, which will then go to your amp, to properly separate frequencies.
Silk and textile tweeters produce a softer sound than Mylar or aluminum, but are more prone to distortion since they are not as stiff. I will recommend, however, that if you haven't put good sound deadening in your car, you will most likely be unhappy with the sound the silk tweeters will produce as they don't project sound like a metal dome tweet does.
Old May 5, 2013 | 06:17 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Does this work?
Anyone try it?
Morel make great sounding tweets (to me anyway ). Good choice for pillar install.
I'm also a big fan of Focal (amazing mid sound) but would take -3 db off the tweet to reduce the "detailed" sound. The crossover has a setting to do just this...seems it's a popular option.
Old May 12, 2013 | 05:38 AM
alicat's Avatar
Car: 1985 z28 camaro
Engine: 305 lg4,edelbrock,3"air cleaner.k&n
Transmission: turbo 700r4 w/b&m megashifter
Axle/Gears: Stock.
I have alpine tweeters in the A pillars with the mids in the dash,where the original
speakers were.They are amped through a crossover,and i get decent sound from them.I dont lose any sound detail.
Alicat.
aharvel50
Sep 21, 2015 07:31 PM
tcflint
Sep 14, 2015 04:55 AM
Omega
Aug 10, 2015 12:46 PM
BowtieFever
Car Audio
Dec 20, 2001 10:13 PM
Mike Harvey
Car Audio
Dec 10, 2000 03:41 PM
