amp and sub info
Old May 11, 2013 | 03:58 AM
gio.cortes89's Avatar
Car: 92 firebird
Engine: v6 mpi
amp and sub info
hey what would be a good set up for a 92 firebird...looking to add some bass in my audio system...how many subs should i get and also what type of amps should i get as well..also the metal in my rear speakers seem to rattle a lot even on low volume..anyway i can cancel that rattling?
Old May 11, 2013 | 06:01 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: amp and sub info
There are LOTS of sub/amp combo's out there.
First need to know;
What music do you listen to? How "loud" do you want the sub to be?
What is your budget?
What brand are your other speakers?
To eliminate the rear speaker rattling, buy some thin peel and stick foam and apply between your speaker and the housing. Rattling probably is caused by metal to metal contact. Best to have a barrier between the two.
Also, Dynamat/Fatmat or similar product trimmed will work as well.
Old May 11, 2013 | 11:56 AM
Car: 92 firebird
Engine: v6 mpi
First need to know;
i mostly listen to house and hiphop music...i run pioneer on the back and dxi in the front...i spoke to someone at best buy who installed my headunit and said an amp and one 12inch sub would run around 400...i guess i would spend around there to 700 with parts and labor..basically i would like a good bass
Old May 11, 2013 | 07:24 PM
Car: 89 IROC
Here are my suggestions....
12" sub
http://www.sonicelectronix.com/item_...GTO-751EZ.html ..this thing kicks hard.
or
http://www.sonicelectronix.com/item_...-GTO1214D.html
Amp
Old May 11, 2013 | 07:53 PM
devestator_x's Avatar
Car: 2001 Camaro
Engine: 3800 Series
Axle/Gears: ??
If you want to keep the budget nice and tight while still pumping out some good sound, this is what i have in my car currently...
http://www.sonicelectronix.com/item_...12-JXWXv2.html
Set gain according to the manual using a 50hz test tone at 3/4 volume and you're good to go. Its great because you dont have to worry about the sub and amp being a mismatch in power. I've listened to everything from Skrillex to Young Jeezy to Bass I love you on this and it just pumps it out without ever skipping a beat.
Its not earth shaking and you need to take the amp off the back of the box to get it to slide down into the rear well, but it fits nice and snug and the echo off the rear of the car helps amplify the bass quite a bit. I tried putting the box on top of the hump in the hatch and the bass much flatter, not as boomy.
Old May 11, 2013 | 10:22 PM
cwoodman1987's Avatar
Car: 1987 Firebird Formula
Engine: 305 4bbl
This is the amp and sub combo I have for my car
http://www.sonicelectronix.com/item_...air-Combo.html
http://www.sonicelectronix.com/item_...-GM-D8601.html
Whatever you decide to get definitely check sonics website, it will most likely be cheaper than getting it at best buy.
Old May 12, 2013 | 01:11 PM
Car: 92 firebird
Engine: v6 mpi
thanks guys really appreciate the help and advice here =D
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
Linson
Oct 1, 2015 09:50 PM
raymondandretti
Sep 27, 2015 06:43 PM
