Hole for amp power line through firewall?
Old Jul 8, 2013 | 08:56 PM
winger67's Avatar
The battery on my '92 Trans Am has been relocated to the right side. Is there a hole though the passenger side firewall or another recommended place that I can run through?
Old Jul 9, 2013 | 03:02 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: Hole for amp power line through firewall?
Find a clear spot and drill your hole, that's about it. I went down into the fender with mine and drilled by the ecm wiring where it bolts to the body but that was for a wire tuck, any clear spot on the firewall will be suitable
Old Jul 9, 2013 | 07:03 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
I ran mine though the power antenna grommet
Old Jul 9, 2013 | 11:51 AM
n1ffer's Avatar
Car: 1983 Crossfire Recaro T/A
Engine: 5.0L Crossfire
Transmission: Upgraded 700R4
Axle/Gears: 3:23
Old Jul 15, 2013 | 10:46 AM
HowDoIDriveStic's Avatar
Car: 1983 Chevrolet Camaro Z/28
Engine: 383 Stroker
Axle/Gears: Posi/3.73
Not sure it its still relevant, but I ran mine through the passenger side fender. You can actually see the wire if you look closely when the door is open lol
Jeremys87
Jul 14, 2022 09:08 PM
mustangman65_79
Car Audio
Sep 8, 2015 08:20 PM
ZsTransAm
Aug 11, 2015 07:30 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Elliswon
Aug 10, 2015 12:33 PM
