What to run 3 10's with
Old Jul 29, 2013 | 08:02 PM
chrisvanguitar5's Avatar
Car: 89 Trans Am GTA
Engine: 5.7 L98
Transmission: 700 r4
I have a custom box I built for my 3 Alpine Type R 10's and am looking at getting amps and whatever else. What should I go with, how many, how should I wire and what about capacitors and batteries?
Chris
Old Jul 29, 2013 | 08:16 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: What to run 3 10's with
All your questions can be answered is you do a search and read up.
www.diymobileaudio.com is also a good place to gain knowledge.
Start with the BIG 3.....
Old Jul 30, 2013 | 08:45 AM
devestator_x's Avatar
Car: 2001 Camaro
Engine: 3800 Series
Axle/Gears: ??
Not nearly enough info here. What ohms are the speakers? What is the power rating of each speaker? Are they dual voice coil or single voice coil?
If I say, use a 1000 watt monoblock amp and each speaker is only rated at 200watts, you will burn them up. If I say get a 500watt amp thats only 2 ohm stable and each speaker is rated for 500watts and are running at 4ohms each, you will cut it down to 1 ohm and burn up the amp.
This link along with the one above can help you greatly...
http://www.crutchfield.com/S-xooJSNx...rs_wiring.html
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
ezobens
Aug 19, 2015 10:29 PM
