New System
Old Sep 10, 2000 | 11:40 PM
Topgun's Avatar
New System
I am working on a new system for my car. I have a new Head unit, JVC KD-SX750. New 6X9's Kenwood 3-Ways. Was thinking about a single sub, a Pioneer 10" Sub, TS-W253C. In a sealed box. Powered by a 4 channel Jensen Amp. Was going to run my 6x9's off this amp and bridge 2 channels for the sub. Just to let you know. I don't have much money. I wanted a bandpass box but it isn't going to fit in the back. Pluse it is to expensive. What do you think, am i going the wrong direction. I do have a Diagram, for what i am going to do. it is in .BMP format. 2 diagrams to be exact. 1 is how i am going to wire it to my 6x9's and sub, the other diagram is how i am going to run the wires in my care. I would love any imput you can give. and any advice. thanx
EMAIL: CTopgun5@aol.com
_______
84' Z28
350 Ci 4 Bolt Main with all L69/HO Parts
4 BBl Carb
160º Thermostat
K&N High Flow Filter
700R4 Trans
15X7 Standard Z28 Wheels, With 215/65R15 BF Goodrich Comp T/A HR4 Tires
Charcol in Color
no T-tops, but wish
New Head unit, JVC KD-SX750
New Kenwood 3-Way 6X9
As FiremanZ28 says "Friends don't let Friends Drive Mustangs"
Pic of my Z28, thanks to ZZ4 and his web page: Http://www.geocities.com/ukzz4iroc/z28camaro.jpg
Old Sep 11, 2000 | 03:26 AM
firestorm's Avatar
Car: Firebird
Engine: LG4
Make sure you use high quality RCAs from the deck to the amp.
Wheels of fire burn the night, Ride across the sky
Wheels of fire burning bright, We live to ride
Old Sep 11, 2000 | 11:08 AM
xybertron's Avatar
If you wanted bandpass I am sure you want some bass so I would suggest a sealed 12 to account for the 6 db loss when comparing a bandpass to sealed. Image Dynamics makes awesome sealed subs that run with low power. I would look for something other than a Jensen amp. Goto www.crutchfield.com and look at what they have on sale. I would personally get the Infinity thats on sale. And make sure to use twisted pair rca's and run them away from the power wire. Also set the 6x9's to high pass at 80 Hz and the subs low pass at 80 Hz.
Old Sep 11, 2000 | 10:40 PM
Topgun's Avatar
I am kind of new to car audio, what do you mean, low pass, and high pass?
_______
84' Z28
4 BBl Carb
160º Thermostat
700R4 Trans
Charcol in Color
no T-tops, but wish
New Kenwood 3-Way 6X9's
Old Sep 11, 2000 | 11:20 PM
poorboy8's Avatar
Car: 79 Camaro RS
Engine: 355, carb, alum heads, XE262
Transmission: TH350
Another words your six by nines will play anything from eighty hertz and above and your subs will play anything from eighty hertz and below. Hence High pass filters and low pass filters. The objective is to have all your frequencies covered in the setup of the system!
j.wolfe
________
91 GTA
ET: 15.3@89.2mph in OD taking it easy on 190,000 mile engine!
Old Sep 11, 2000 | 11:25 PM
Topgun's Avatar
Ok, i understand. The amp i want has low pass inputs and high pass inputs, now i understand. but it has 2 inputs of each. 2 left, and 2 right for low pass, and same for highpass, only i will only have 4 rca's coming from the head unit. 2R and 2L. so, how do i wire that up? Man i am confused
_______
84' Z28
4 BBl Carb
160º Thermostat
700R4 Trans
Charcol in Color
no T-tops, but wish
Pac J
May 17, 2020 10:44 AM
jrdturbo
Mar 31, 2016 02:58 PM
1992Z28!
Nov 19, 2015 07:33 AM
Night rider327
Oct 9, 2015 09:25 AM
Night rider327
Sep 25, 2015 04:47 AM
