Is my amp going out on me?
Old Sep 13, 2000 | 05:29 PM
Mr_Sinister's Avatar
It thumps. Rythmicly thumps. Even if the stereo is turned all the way down. THUMP, THUMP, THUMP, THUMP. Bad wiring somewhere, or is this my first bad amp?
Old Sep 13, 2000 | 05:35 PM
GndPrx's Avatar
My first guess would be to check and make sure you didn't run your power wire near any spark plug wires under the hood. If you have older wires or frayed wires they will cause a ticking or thumping through your system.
That would be the first place I'd look.
GndPrx http://www.caraudioresources.net
Also try disconnecting your remote turn on lead, turn the radio off, jumper the power lead to the remote turn on to cause the amp to power up. With the radio off and the amp powered on, do you still hear it?
If not, then it's somewhere from the radio or RCA's before the amp. If you do still hear it, check all of your wiring on the amp (power, gnd, etc..) and make sure nothing chafed through the insulation to expose any wire.
l8rs
[This message has been edited by GndPrx (edited September 13, 2000).]
Old Sep 15, 2000 | 07:23 PM
chuck s.'s Avatar
you have a bad ground on your gnd. wire scrape the paint off and screw it down tight. also check the rca try grounding the sheild on it( the outer conductor).hope that works!
chuck saunders @Wild Bill electronics m.e.c.p. cert.first class
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
