passenger 6x9 not working
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Hey guys. Installing some new speakers in car and so far iv got them all going except for the passenger 6x9. It use to work when I had my old Sony xplodes in it, then one day it just quit working. Well I figured I blew it as I'm not easy on speakers. Well I'm replacing them with some jbls and I still can't get it to do anything. The wiring where I spliced into the factory wiring for my after markets seem to be holding strong. And my splicing behind the radio itself is strong and looks good. Any idea from on where I should start? I'm currently removing the trim so I can look at the wire all the way back to the speaker its self, but the front speaker works fine and their on the same plug.
Re: passenger 6x9 not working
Try swapping left/right connections at the head unit to see if the other speaker quits -and/or- a continuity test of the speaker wires.
Jeff ~
Jeff ~
Engine: L31 350
Thanks. It looks like the connector I was talking about earlier is the connector for both rear speakers. I'm going to try and bypass the factory wiring first and see if that works better or helps. It sucks that I can inky hear one jbl
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
continuity, put one meter lead on one of the wires by the radio and the other lead by the speaker on the same wire should read zero ohms for both wires, if not you have to fix it or run new wires
Engine: L31 350
I ran new wires last night. Got my speakers working now so I just gotta run my amp wire and my rca cables
