POWER WIRE QUESTION, jim85iroc
Old Sep 24, 2000 | 04:35 PM
myposcamaro's Avatar
-what guage Power Wire would i need to run a Power Acoustik 680watt amp?. right now i have 10 guage Power Wire. Does anyone know?
-Also.. is a Power Acoustiks amp any good?
-How about the GRDs and REMs wires? should i get a higher guage for them too?
thanks!
Old Sep 24, 2000 | 06:24 PM
Wraith's Avatar
I would use at least a 4-gauge wire. I ran 2-gauge wire w/100 amp fuse running 2-punch500m, 1-punch200 and a punch100 and it worked just fine. As for the grade of the wire go with the base model stuff anything better and it's just a waste of money.
1991 Trans Am GTA, Accel 300+ ignition, underdrive pulleys, AFPR, Accel SuperRam (ported out), Edelbrock lower intake (ported out), BBK 58mm TB, TFS 23* heads, SLP 1 3/4 headers, SLP 3" cat back (no cat), CompCam .495/.502 lift, Kenny Bell strut tower brace, lower frame brace, Jeg's SFC, Lakewood trailing arms and panhard rod
Pony's can run, but bird can fly
1987 Buick Turbo-T
1977 Chevy Blazer 4X4
Old Sep 24, 2000 | 08:42 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
How many ampers is the fuse rated for thats on the amp?
The power and ground wires should be the same gauge. The remote wire can be just a thin wire since it only supplies a 12v source and not current.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6 Now Bilstein equipped!
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
Old Sep 25, 2000 | 07:17 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Yeah, what Justin said
In my previous experiences, power acoustik amps are grossly over-rated, which is why you should look at the fuse. That will help determine exactly what you need.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
BRoss99
Aug 10, 2025 05:08 PM
MustangBeater20
Oct 29, 2022 09:20 PM
Caspar
Jun 19, 2016 11:19 PM
redmaroz
Aug 16, 2015 11:40 PM
stalkier
Aug 13, 2015 12:59 PM
