UX1 radio does not work
Old Mar 8, 2014 | 04:03 PM
Hawkeye1980's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7
Axle/Gears: Stock
Hi fellow third gen folks!
Well my 89 Formula 350 has been on the road since Jan and I can wait until summer! Couple of minor issues but one i want to fix ASAP.
My Radio, UX1, it was working great unti recently. It wont come on when powered The power antena does not go up either. The clock works fine.
Just so its known, I did solder in a 3.5MM stereo jack so I can play music off my smart phone. That worked great too
I am thinking that the jack I soldered in maybe the issue. Just wondering however if it could be something else. The fuses for both the radio and antenna are fine.
So I know the radio gets power but will not power on with the orange button. I would be greatful for any thoughts, etc. Thanks!
Old Mar 8, 2014 | 05:02 PM
red88tagta's Avatar
Car: Restored 88 GTA
Engine: 5.0
Axle/Gears: Posi
Re: UX1 radio does not work
Well my 89 Formula 350 has been on the road since Jan and I can wait until summer! Comple of minor issues but one i want to fix ASAP.
The power button switches are known to go bad. Remove the radio bottom and cassette, jumper the switch at the main power board. Radio should power up.
Old Mar 9, 2014 | 12:45 AM
Engine: 5.7
Axle/Gears: Stock
Thanks for the info. The button it self seems to work fine. But I will jump the connections to confirmif this is the issue. Can it be fixed/replaced?
Old Mar 9, 2014 | 08:29 AM
red88tagta's Avatar
Engine: 5.0
Axle/Gears: Posi
I'm sure I can find a few around here that are good. I'll be glad to mail you one.
Old Mar 9, 2014 | 11:12 AM
Engine: 5.7
Axle/Gears: Stock
Sure! Let me know! Thanks! Would be good to have one ethier way. Let me know how much etc.
Old Mar 9, 2014 | 11:48 AM
Engine: 5.7
Axle/Gears: Stock
I was not able to jump the power switch. However I moved the 2 leads and got it to power up couple of times So pretty safe to say its the switch. Please let me know if you have them thanks again!
Old Mar 9, 2014 | 10:47 PM
*84TA's Avatar
Car: 84 Trans Am
You can also buy a NOS switch from http://www.corvetteradios.com/corvetteradios_020.htm if red88tagta doesn't have any.
Old Mar 9, 2014 | 11:20 PM
Engine: 5.7
Axle/Gears: Stock
Thanks! At least I know there are sources for this part. I will wait to hear back from red88tagta first.
Old Mar 15, 2014 | 03:09 PM
Engine: 5.7
Axle/Gears: Stock
Thanks to red88tagta I am good to go, it was the power switch that was bad.
Old Mar 16, 2014 | 06:46 PM
*84TA's Avatar
Car: 84 Trans Am
Glad to hear your back up and running.
Vintageracer
Jan 10, 2020 05:33 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
89redeyeRoc
Car Audio
Aug 24, 2015 07:01 AM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
