cd player installation kit for digital dash car
Old Jul 16, 2014 | 10:16 PM
sheikss's Avatar
Car: 88 Trans Am GTA
Axle/Gears: 12 bolt 3.73
So I installed a cd player into my 88 gta w/digital dash. The installation kit is the normal gm kit for an f body. It doesn't sit far enough back to allow the trim to go back on. I can't modify the installation kit to work. What do you digital dash guys do/use?
Old Jul 17, 2014 | 07:25 AM
Caveman305's Avatar
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
Re: cd player installation kit for digital dash car
use scosche 1516b
in camaros you have to heat and remold the air ducts behind the radio to make a single din fit, but other than that it sits nice and flush
Old Jul 17, 2014 | 07:41 AM
sheikss's Avatar
I took care of the duct work. The installation kit itself doesn't sit far enough in. I might be able to cut the tabs off the kit and make my own brackets. Just wanted to see if there was a better kit. I will look at the kit you mentioned.
Old Jul 17, 2014 | 08:04 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
I have the digital dash in my 88 GTA and I installed a Alpine headunit. It will stick out about 1/2 to 3/4 of an inch. I had an earlier Alpine 20 years ago that had the adjustable mounting tabs that you could adjust the depth to make it flush; which was nicer/cleaner looking. It was a double DIN with the EQ.
Or, you can remove the little tab behind the radio for the stock radio and slide it back flush, but you'll have to mod the 2 side brackets to the new radio.
Old Jul 17, 2014 | 08:19 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Here's some pic's of mine with the trim plate on
Old Jul 17, 2014 | 08:55 AM
Caveman305's Avatar
Engine: L03, LB9
right, i meant with the scosche kit in the camaro you have to modify the ducting, if you are using the style Bob88GTA has no modification is necessary
since you have a Bird, and already modified the ducting, the Scosche kit should install very easily into your car, and make the unit flush without the bump out seen in Bob88GTA's pic
not sure if it will resolve the problem with the bezel not sitting flush or not, it is just my preferred kit in thirdgens and only cost $9
Old Jul 17, 2014 | 08:58 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
it is just my preferred kit in thirdgens and only cost $9[/QUOTE]
Where do I get one? I want mine flush like it used to be with my old Alpine
FOUND IT, Thanks!
hectre13
Dec 11, 2023 08:14 AM
rocn7roc
Sep 21, 2021 02:16 PM
Terrell351
Jun 13, 2021 01:13 PM
beachrodder
Aug 7, 2015 04:27 PM
drathaar907
Aug 6, 2015 04:20 PM
