multiple inputs?
Old Oct 1, 2014 | 07:30 PM
nater's Avatar
Car: 1984 camaro berlinetta
Engine: v8
multiple inputs?
would it be possible to use both the high level inputs on my amp and the rca cables, but for different inputs. i would use the high levels obviously for the head unit, and the rca would be for an aux to my phone (i only will use one at a time). my amps manual says not to use both but they way i am interpreting it is not to use both inputs from the radio, but will it hurt anything if i dont use both at the same time. i do understand that this will eliminate my balance and eq settings in "aux mode".
Old Oct 3, 2014 | 09:06 PM
-srs-'s Avatar
Car: 1991 Z28 Vert
Re: multiple inputs?
It's possible...but you would have to be pretty handy at wiring relays. You definitely don't want to feed that amp inputs from both sources at once.
Old Oct 3, 2014 | 11:34 PM
nater's Avatar
Engine: v8
well i would just shut the radio off when i plug in my phone and could also wire in a switch for the radio if need be. i just wanted to make sure i wouldnt fry something just by having it hooked up
Old Oct 4, 2014 | 07:32 AM
irocwagon's Avatar
Car: camaro84.87iroc,91vert
Engine: Lt1, 383tpi,350tbi
Transmission: t56,T5,T5
Axle/Gears: 4thgenunknown,373,323?
Why not just get a radio with aux...
Linson
Oct 24, 2025 02:00 PM
cheesehomer
Dec 31, 2015 08:48 AM
HoosierinWA
Oct 7, 2015 10:15 AM
Linson
Oct 1, 2015 09:50 PM
Dragonsys
Sep 25, 2015 03:51 PM
