Infinity 4x6 question
Old Nov 10, 2000 | 08:15 PM
CCar_182's Avatar
Hi,
I just bought a pair of the infinity 4x6 plates for my 92 camaro. The passengerside speaker seems to fit fine....But the driverside speaker wont fit..There seems to be a plastic piece in the way. I know some of you people have these speakers in your camaros/firebirds and im wondering how to fix this problem.
Old Nov 10, 2000 | 10:02 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
I just cut out some of the plastic so it would fit.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6 Now Bilstein equipped!
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
Old Nov 10, 2000 | 10:08 PM
CCar_182's Avatar
so that plastic is nothing important?
Old Nov 10, 2000 | 10:48 PM
Jason E's Avatar
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
Put spacers in the brackets to raise the LF speaker up within the mount. Thats what I did when I had my Infinity 4x6s.
Jason E
'89 Camaro RS 2.8
Hypertech chip/K&N filters/Accel 8.8 wires/RapidFires
Eclipse CD and 100x4 amp/Boston plates and 6x9s
Alpine Alarm w/ Keyless entry
IROC tailights/tinted windows
Old Nov 10, 2000 | 10:49 PM
Jason E's Avatar
Don't cut plastic...you never know what you might be cutting into!
Old Nov 10, 2000 | 11:02 PM
CCar_182's Avatar
but wont the speaker be in the way of the built in grille of the dash?
Old Nov 11, 2000 | 12:59 AM
Take your time and carefully look what your cutting into. The black plastic can be safely removed as long as you dont remove and parts that have screws that go into it. Below the black is white plastic. Dont cut that, that should be your inst panel that holds all the gauges. This info is from my Firebird, so Camaros may be a tad different, i dont know. But they do fit my Firebird and removing the black plastic caused no probs.
-Justin-
[This message has been edited by Justins86bird (edited November 11, 2000).]
Old Nov 11, 2000 | 08:07 AM
turbo497's Avatar
I have these in my car. to get it to fit on drivers side remove gauge cluster and small heater routing vent. trim and duct tape vent and cut black plastic support to make room for magnet on back of speaker.
Old Nov 11, 2000 | 01:08 PM
Velocity's Avatar
I dont have the infinity's, but my clarions are about the same size, and I just had to do some reshaping to the plastic to get it to fit. at least in a bird it wont do any damage...unless you get carried away.
'87 GTA
Automatic 350 TPI
2 3/4" Flowmasters
K&N filtercharger
4 3/4" Glasstech Cowl induction hood
TPI intake air foil
System:
Panasonic DFX-99
2 12" RF DVC's
RF 250.2 (Custom
RF 200.4 Painted)
Sony 10 disc changer
Clarion Pro Audio 4x6's
Old Nov 11, 2000 | 03:50 PM
CCar_182's Avatar
Well tomorow i am going to figure it out... First i am going to try the spacer idea. If that doesnt work then i will have to cut plastic. Hope i dont screw up!
Old Nov 11, 2000 | 11:37 PM
Chris Luongo's Avatar
Read the tech article on this site for some good installation instructions. I couldn't get my Infinity plate to fit on the driver's side of my Firebird either, so I had to cut away some of the hard plastic, and I also had to heat the defroster duct with a heat gun and slightly reshape it (by pushing on it with a stick).
Old Nov 13, 2000 | 10:29 AM
Jason E's Avatar
The spacer idea should work. That's how my Infinitys were set up in my RS. I've had 5 sets of front speakers in my car (Alpine, Infinity, Polk, Boston 4x6s, and Eclipse 6.5s), and the only ones that touched the grille were the 6.5s. As a matter of fact, the only ones I needed spacers for were the Infinitys!! Spacers if done correct will allow you to fit them in without cutting, and should give you about 3/8 inch clearance with regard to the dash grille.
Admittedly this is for a Camaro...I have no idea if this will work for a 'Bird too.
Jason E
'89 Camaro RS 2.8
[This message has been edited by Jason E (edited November 13, 2000).]
Old Nov 13, 2000 | 11:02 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I've done a couple. I used Boston 746 plates, which because of the huge, offset magnet, require a lot of fabrication. I had to trim a lot of unimportant plastic, but still had the heat duct in the way. I heated it with a heat gun and pushed it back with a stick until I had sufficient space for the speakers. In cases where the tweeter sticks up, it is also sometimes necessary to trim some of the underside of the speaker grill. This is not biggie and not really noticable once it's installed, but what I did was cut out the entire center section of the grills so that just the skinny frame was left, then I stretched grill cloth over the frames and dropped them back into place. They looked like they came from GM that way, and only a hard-core Firebird guy would ever be able to distinguish these grills from the ones that came in the Premium firebird stereo.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Nov 20, 2000 | 06:23 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
just go ahead and cut into the plastic. it's just the air duct, nothing more, nothing less.
Old Nov 21, 2000 | 08:01 PM
CCar_182's Avatar
I ended up just using spacers....the speaker still has room until it hits the dash..and i didnt have to cut anything!
thanks for the ideas
Old Nov 21, 2000 | 10:44 PM
Jason E's Avatar
Glad to hear it!!
fasteddi
Sep 10, 2015 09:32 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
