How to get 8" subs in 6X9 locations?!!!!!!
Old Nov 22, 2000 | 09:31 PM
Matt Finch's Avatar
Car: 1982 Trans Am
Transmission: Turbo 350
Axle/Gears: 3.23:1
I have a couple of free air pioneer 8" subs that I wanted to place in my 6X9 locations. Can any one tell me How? Any Pics?!!
Thanx in advance!
Matt Finch!
Old Nov 23, 2000 | 01:29 AM
Jeremy_84_F41's Avatar
Car: 1991 Formula L98
Axle/Gears: 3.73:1
Well, depending on the size of the basket and magnet, you should only have to use a dremel or something similar to make clearance for the speaker (basically make it more round, although it might fit without modification), and drill holes wherever needed to mount the speaker.. not too difficult. I'd start by taking out my 6x9's and holding the 8" up to the hole and see where it's going to contact, and go from there.
Old Nov 23, 2000 | 11:14 AM
will0325's Avatar
Matt, i hate to say this, but 8's in ur sail pannels would just be a waste of money. i really hate to rain on ur parade but the sail panels don have enough volume to get good bass reproduction. just look now, find a car w/6X9's mounted regularly w/basket in the trunk and listen to the bass.......sounds almost like a sub. now listen to urs........sounds like sh*t. the sail panels are too shalow to get good bass outof them. 8's just will sound flat and u will get very little bass out of them, but hey go for it and see what happens. i wold love to hear about the results if it came out nice.
Old Nov 23, 2000 | 12:17 PM
knighthelm's Avatar
I have actually seen someone do this. It sounded good but not great, but all he wanted was mid bass. They had to cut a rather large hole into the side, actually the whole side out and custom make a fibreglass box in the hole, He had to refab a cover to fit and cover the subs but it looked good. But you have to find the right sub to get a good sound.
Anything is possible if you have a good enough imagination, and an unlimited cash flow.
Old Nov 23, 2000 | 09:39 PM
Chris Luongo's Avatar
A friend of mine at work was also saying that Orion makes a very shallow 8" free-air woofer that we could probably get to fit in our doors.
Old Nov 23, 2000 | 10:15 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Please let me know what you do. I'm planning to put a pair of Kicker Free-air 8's in my car to carry out the midbass duties. I would simply go with 6x9's, but that would be too easy! Also, the 8's are marginally better than 6x9's. The specs look pretty darn close, but the actual sound is just a bit better. I hope to get to this sometime in January.
Working on:
'84 Z28 LG4 305
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350
using primarily GMPP parts.
Block is in shop!
Awaiting results from all 8 ASE tests.
Starting to look like the Kicker poster child!
Old Nov 24, 2000 | 02:06 PM
knighthelm's Avatar
Chris
My friend was going to put an 8 inch in the door for mid bass, but the problem came up that once installed the speaker would prevent the window from rolling down all the way, We scraped the idea, since you can not cruise in a Camaro with the windows up
Old Nov 24, 2000 | 11:24 PM
knighthelm...you could also build the doors out slightly. A crude example would be a couple of slabs of plywood screwed together, with an 8" hole cut in the middle. You could then carpet the plywood to match the car, or make something nice and custom with fiberglass. (But I'll never give up my factory cupholders i9n my Formula anyway.)
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
vortec tpi
Sep 26, 2015 08:14 AM
Nikole
Sep 24, 2015 08:12 PM
Abubaca
Car Audio
Sep 24, 2015 02:33 AM
tonys91rs
Sep 2, 2015 07:07 PM
