Stock amp
Old Aug 19, 2015 | 09:51 PM
mustangman65_79's Avatar
Car: 1989 Iroc
Stock amp
My Iroc has the ERS system, which means somewhere is a factory amp. Question is, where is it? I'd like to install a better amp, and maybe use the stock wiring.
Old Aug 20, 2015 | 12:12 AM
kmcn47's Avatar
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
Re: Stock amp
pretty sure most cars got the badge without the system. basically it was just slightly better speakers in the rear. there is no amp
Old Aug 20, 2015 | 02:59 AM
Car: 1989 Iroc
Re: Stock amp
There must be, as none of my speakers worked until I hooked up the (amp?)power wire.
basically I had the wiring kit, but still had to hunt down the amp wire to turn them on.
Old Aug 20, 2015 | 11:39 AM
kmcn47's Avatar
Transmission: 5spd
Re: Stock amp
theres a red power wire, thats keyed 12v the yellow is 12v constant none of the other wires should have power.
Old Aug 20, 2015 | 08:05 PM
OLDYELLR's Avatar
Car: '85 IROC
Re: Stock amp
That's what my IROC has. Just the stereo/cassette with equalizer, no separate amp. maybe the speakers is all.
Old Sep 8, 2015 | 08:20 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Stock amp
No - There is no AMP with the "Extended Range Sound" option.
The only Thirdgens that got FACTORY amps were the Firebirds with a the "Subwoofer" system ('GAIN' button on the dash ) or a Camaro with the factory BOSE option. ( says 'BOSE' on rear speaker panel )
RazorN8
Jan 7, 2022 11:44 AM
Genopsyde
Oct 7, 2015 08:35 PM
SPEEDY Z28
Aug 17, 2015 01:46 PM
ZsTransAm
Aug 11, 2015 07:30 PM
