MDF, best wood?
Old Dec 1, 2000 | 09:10 PM
86V6's Avatar
MDF, best wood?
I was wonderinf if 3/4" MDf is actually the best wood or the most practical due to the cost/performance. Would a harder wood like birch or oak be better? Y or Y not. I have access to extra wood so price is not the issue. Just seeing what u guys think.
Old Dec 2, 2000 | 06:51 PM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
Actually,the best for high powered sub enclosures is 5/8" HIGH density particle board because it is more dense and has less resonant qualities than MDF.It's inexpensive,but absorbs moisture and wears down saw blades quick. 3/4" MDF is really good also,but not quite as dense. It is easy to cut,but has a tendency to split when fastened with screws.When I build enclosures for customers,I put the pieces of wood together with Liquid Nails and use a pnuematic nail gun so the wood doesn't split.
Just remember,the higher the density,the better the enclosure will perform sonically because of limited flex in the enclosure walls.
Old Dec 2, 2000 | 09:53 PM
daniel dekay's Avatar
particle board is nothing more than left over saw dust glue together. if you have a leak or any kind of moisture the particle board will soak it right up. i alsways use or insist on MDF simply because i dont want my box to become a sponge. hes right tho, particle board is cheaper.
daniel
Old Dec 2, 2000 | 10:56 PM
86V6's Avatar
so the higer desity, the better? what about wood like oak and birch? thanx
Old Dec 3, 2000 | 01:41 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
When ever i make a box, i drill pilot holes first. Then i put glue on the edges, line up the holes and power drive the screws in. No splits. Nails may be easier to use, but dont hold as well as screws. Maybe the pnuematic nails with the glue you use work better, but from home construction experience, nails seem to want to pull out after time.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6 Now Bilstein equipped!
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
Old Dec 3, 2000 | 05:14 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
I like particle board because unlike real wood, it has no grain and it wont flex in any one direction more than another. Plus it is cheap... Heres my box
<img src="http://fbody.800mph.com/ward9.jpg" alt="My subs">
1983 Pontiac Firebird SE
LG4-Based Chevy 400
700R4 Tansmission
Modified 4 Barrel Q-Jet Carb
Accel Super Stock 8mm Wires
Edelbrock Pro-Flo Air Cleaner
3.23 Posi Rear
14X7" Cragar SS/T Wheels
35X4 CD/AM/FM Head Unit
100WX2 Amp
2 Pioneer 12" Subs in Custom Box
Third Gen Performance
"A four cylinder is only half an engine
Old Dec 3, 2000 | 10:09 PM
RSpeed's Avatar
True,nails do tend to pull apart.But I use 2 1/2" nails.And with the Liquid nails between the pieces to hold it together and seal it up,the box is not coming apart.I tried to pull one apart one time.Everything broke except for the joints.I can build a box like this in half the time it takes doing it with a screw gun. And as far as particle board being made of small pieces of wood and sawdust,true.But that's why I stated 5/8" HIGH-DENSITY particle board.It is pressed together under extremely high pressure and will not fall apart,leak air,or anything like that.Yes,it will soak up water,but so will MDF.Both will swell up if wet.But you're not putting it in a boat are you? If you think your car might have a leak and the box could somehow possibly get wet,then spray on some polyurethane or fiberglass resin.Simple enough. As far as birch,oak,etc.You can't find them in sheets like you can MDF,etc.So it would really not be worth it to join a lot of hardwood boards together to build a box.
[This message has been edited by RSpeed (edited December 03, 2000).]
Old Dec 4, 2000 | 10:26 AM
86V6's Avatar
Actually, I have access to the wood, my father is a superintendant for construction and I can literally get oak ect in sheets for free. I have learned HDF is good because it doesn't flex in specific points, but I do not think oak would flex at all. Just wondering if there was a specific reason MDF was used so often...i guess it was just cost....
Old Dec 4, 2000 | 03:02 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Although hardwoods make great tables, they are not as well suited to box building as MDF. Although they are dense, they still have a much higher tendancy to resonate due to an inherant weakness and flexibility with any grain material. The Particle board is like a bunch of wood chips and glue smashed together under high pressure. MDF is like wood powder and glue that is pressed together under high pressure. Because of this, it exhibits very good rididity and resistance to vibration. Although hardwoods are very rigid, they are succeptable to vibration. Some of the finest home speaker enclosures in the world use MDF with a real wood laminate for appearance. Those that do use real wood have substantial internal bracing.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Dec 4, 2000 | 04:07 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
i work in a home-depot-type place in the lumbner department, so i have seen a lot of different things. i also have built probably a dozen boxes for myslef and my friends.
here's my take on what to use...
use MDF for surface the speaker mounts to. it seems to hold the 8 screws that hold the speaker in better.
use a 3/4" HIGH DENSITY particle board for the rest of the box. this isn't regular particle board. it is called Nova Ply where i work. it is good stuff...really good stuff.
as far as teh water thing, i had my box in a leaky hatch for a while, and nothing at all happened to it. nothing. it was totally fine.
and, the prices for 3/4" MDF and 3/4" Nova Ply are really close. like 15 bucks a sheet up here in NY.
-brian
1991 Camaro RS - Ultra Blue Metallic, T-Tops
GM 350 HO Crate Engine - Vortec Heads, Edelbrock Performer Vortec Intake, Holley 670 CFM Throttle Body, Open Air Cleaner w/14"x3" K&N, SLP 1 3/4" Stainless Headers, Edelbrock Victor Series Water Pump, Accell Superstock Wires, Cap, and Rotor, MSD Blaster Coil, Hypertech Fan Switch & Thermomaster Chip, AC Delco Rapidfires, 3" Cat Back, Flowmaster 40 Series Muffler
700R4 - 2,400 Stall Converter, Vette Servo, Shift Kit, B&M Super Cooler
Brian's 1991 RS
Central NY F-Body Association
Join the Third Generation F-Body TBI Web Ring
z28boy@twcny.rr.com IM name: Z28 Boy
Old Dec 4, 2000 | 06:53 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
A friend(and professional installer)who built the enclosure for my Formula uses 3/4" birch with great results. He's built boxes that actually gained a few db with birch as compared to MDF.
Mongoose-NCTGA-1990 Pontiac Formula/305 TBI-700R4 with Edelbrock Performer TBI intake,TES headers,and STB,K&N,MSD-6AL,Holley laser shot coil,Accel Extreme 9000 wires,Jet Stage 2 chip,TCI shift kit with corvette servo,Richmond 3.73 gear with Auburn 3 series posi,no cat,SLP 3" cat back,Eibach sportline springs,Energy Suspension poly throughout,Lakewood LCA and adjustable panhard bar package,SSM subframe connectors,IROC wonder bar,Tokico 5 way adjustable struts and shocks,Autometer electric fuel pressure gauge,Alpine,JL Audio,MB Quart,92 GTA taillights,92 GTA aero wing and hatch,Steve Spohn LCA relocater kit,MacEwen White face gauges,84 T/A cold air induction air cleaner.
S10K20
Oct 7, 2015 06:45 PM
skinny z
Oct 5, 2015 06:23 PM
nagga
Car Audio
Dec 8, 2001 10:43 PM
Ragin'87
Car Audio
Jul 2, 2001 03:03 PM
KlayBuRn
Car Audio
May 15, 2001 02:20 PM
