hey jim...
Old Dec 7, 2000 | 04:35 PM
scoob8000's Avatar
Car: 95 Caprice
Engine: 5.7l LT1
Axle/Gears: 2.93
hey jim...
i saw a post on the electronics board something along the lines of.. if you run a system you should run at least say a 8ga from the alternator directally to the battery along with the normal wire to the distro block, to maximize alternator life.. sound like a possibility to you?
Old Dec 8, 2000 | 06:26 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
It can't really hurt. The alternator will be supplying the power via your battery, so technically I suppose you should have the same gauge as you use to go to your distribution block.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Loudnproud86
Jul 14, 2016 12:59 AM
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
Zane Story
Oct 8, 2015 12:40 PM
chuck13
Interior Parts Wanted
Sep 22, 2015 11:19 AM
Keiffer76
Sep 9, 2015 08:52 PM
