wierd 2ch. amp malfuntion,..I can't even begin to comprehend.....
Old Dec 15, 2000 | 01:02 AM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
here goes, I got my alpine V12 2ch. amp back from circuit citys repair service today.I originally brought it in for "low output & distorted bass fidelity",it had a sign on it that said "please check your speakers",according to the service slip "labor charges of $54.00 were covered by your circuit city extended service policy"
repairs performed on APN MRVT502 :
"electrical alignment of a circuit was made to audio circuit" I don't know about you,but being in the field of electronics repair myself,that sounds like a bunch of Bull sh*t! now heres the wierd malfunction that baffles me(car stereo is a grey area for me) when the balance is thrown all the way to the left or right,the bass hits harder than both speakers together. when it is balanced,it seems to "cancel out" the bass,upper frequencies aren't as noticable. it's not the head unit,I checked that already,it can't possibly have anything to do with the speakers.feel free to get as technical as you need to,to explain.if your not a tech,I still would like to know if youv'e conquered this problem.where does circuit city find these people??
Old Dec 15, 2000 | 01:28 AM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
You might want to check speaker polarity to make sure the speakers are in phase with each other.I've been in the car audio profession for almost 10 years,and that's what the problem sounds like to me.It may be at the speaker or the amp terminals.If those look okay,it may be internally in the amp.That might be what they mean by "electrical alignment for audio circuit",because output polarity might have been crossed internally. Do you still have the same problem,or was it before the amp was repaired?
Old Dec 15, 2000 | 02:49 AM
Jza's Avatar
Jza
That sounds like phase cancellation. It's always more pronounced in the lower frequency range.
Old Dec 15, 2000 | 11:38 AM
Engine: 2.2
definitly phase cancellation,I double checked the polarity to the speakers.It's still messed up after being serviced by circuit citys non-techs.I didn't notice the balance thing before I brought it in(I don't normally use the BAL adjust)I discovered that after I re-installed it,all I knew was it didn't sound like it should when I first brought it in.what can they alighn inside? they didn't touch any of the user accessable adjustments.
Old Dec 15, 2000 | 12:44 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Reverse the polarity of one speaker. It wouldn't be the first time I found a driver incorrectly marked, so even if everything is visually correct, you could still be out of phase.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mcfastestZ28
Oct 1, 2015 11:23 AM
raymondandretti
Sep 27, 2015 06:43 PM
lanceflame44
Sep 25, 2015 12:28 PM
