speaker problems
Old Dec 18, 2000 | 06:44 PM
squirrelybird's Avatar
speaker problems
There is something wrong with the factory speakers in my 91 bird. Sometimes they work fine,darn good as a matter of fact. Then again, sometimes the passenger side dash speaker starts crackling and then neither right side speaker will play. It's real spuratic. The speakers are in perfect condition. I geuss it's probably the wiring? Tell me what's wrong and how to fix it. It sucks because I've got a changer now but the speakers sound like crap.
Old Dec 18, 2000 | 08:58 PM
Camaros4_life's Avatar
Seeing that it is a 91, I am gussing that the speakers are not bad... So it is probibly the wiring, so here is what you do, get to the speakers and disconect the two speakers wires and tie new speaker wire to the ends of the old wires, then take your deck out and pull the old wires through draging the new wires (this saves time from having to feed wires through that can be a l3itch) Now connect the new wires to the speakers and then the deck where you took the old out... If you have extra $$$ around you should upgrade to a better grade speakers, since the GM ones are junk. Hope this helps.
Old Dec 18, 2000 | 11:03 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
my vote goes to the POS Delco deck.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
andy74
Sep 3, 2015 08:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
greenyone
Sep 2, 2015 03:39 PM
