My brothers stereo wont work, idea's whats wrong?
Car: 1991 Camaro Z28
Transmission: T56 6-Speed
Ok, basically his front driver side speaker kicks on and off (more off than on) and the car audio place told him the channel is gone/going on the amp, if the channel is gone i dont see why it would work perfectly fine when it kicks on, but that was the problem before, now i tried switching the 2 front speakers to make sure it wasnt the speaker and it isnt, when i reconnected the pass side speaker and turned it back on all i get is a loud pop out of the rear speakers and theres no sound, the amp is turning on and the fuses arent blown, anyone have any idea's whats going on with both problems? my guess with the speaker on the front driver is just a loose connection somewhere, hes got an alpine head with 0 watts so the amp is powering his 4 interior speakers..thanks in advance.
1991 Camaro Z28
ENGINE/MECHANICAL MODS:
350 TPI AUTO, Edelbrock Headers, Edelbrock Intake Runners, Flowmaster Exhaust, MSD 8.5mm wires, Autolite Double Platinum Plugs, MSD Cap/Rotar, Random Technology High flow cat, Hypertech Power Chip (160 Deg Thermo), K&N Filterchargers
STEREO MODS:
Pioneer DEH-P6000 Reciever, Q-Logic Dual 10" Bandpass Subwoofer Enclosure, 2 10" MTX Thunder 7000 Subs,
Rockford 250a2 Amp,
Infinity Kappa 4x6" plates & 6x9's
Visit my website/see pics at: Frank's 1991 Chevrolet Camaro Page
1991 Camaro Z28
STEREO MODS:
Rockford 250a2 Amp,
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Use an ohm meter to test the resistance between the 2 wires, and then from each wire to ground. There should be infinite resistance from each wire to ground, and a 4 ohm resistance through the speaker. You may have a wire or terminal grounding out on the chassis.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
The IROC Homepage
dhonda200
Aug 11, 2015 11:50 PM
db057
Aug 11, 2015 10:11 PM
