Can I bridge my deck?
Old Dec 28, 2000 | 06:37 PM
Todd 92 Z's Avatar
All of my speakers and sub are running off of amps,the only thing running off of my deck are a pair of Kenwood 120 watt tweeters thru the front channel. Could I bridge the front and rear channels of the deck too give the tweeters more power without hurting my deck or tweets? My deck is a Pioneer DEH-77DH 45 watts x 4, 22 watts rms.
Old Dec 28, 2000 | 06:44 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
I don't think so. Never even heard of such an option. Besides, the pwr rating on those Kenwoods is most likley max....probably about 40 -50w rms. a high power deck could give you that level anyway
92 Camaro RS LO3, 5-spd, T-tops
Mechanics:
Open Air Element w/K&N Filter, Flowmaster 3" Cat-back Exhaust, Z28 Grille w/aftmkt fog lamps
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-90 Amps powering 2 12" Pro Red subs and 4 Infiniti speakers.
NEXT UP: SLP 1 3/4" Headers/Y-pipe, Centerforce Dual Friction Clutch kit
Old Dec 28, 2000 | 06:48 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
An amplifier has to be designed for bridging, otherwise you will damage it when bridged. A deck is not designed for it. Plus, tweeters don't need much power, so you would get no benefit from doing it.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Dec 29, 2000 | 01:15 PM
formula90's Avatar
Car: 1990 Formula
Engine: 5.7 liter
when you bridge an amp and wire 4ohm speakers in paralel you are dropping the impedance and basicly cutting it in half.(2 ohm) an internal amplifier in a deck cannot be stable in that load. now if you insist on bridging that internal amp in your headunit, you can maybe wire them in series, but that will not give you a proper stereo seperation and will basicly give you a mono signal. hmm..well thinking about again...if you bridge your headunit in series using the rear right channel and front rear channel, and the same on the left channels, then that should be a safe set-up...
I have experience...unfortunatly,its a result of bad judgement.
click below to check out MY FORMULA PAGE!
http://www.formula350.com
or click below to email me
astralbaby11@hotmail.com
Linson
Oct 24, 2025 02:00 PM
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
