How much does your sub box weigh?
Old Jan 10, 2001 | 01:41 AM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
I am asking because I am going to build a box for my 2 12's and want to know how much I should expect it to weigh.
I will probably use 3/4in plywood to build it. I would rather use something like MDF, but I hear that it is not cheap at all. I also hear that 3/4 in plywood stays firm enough for good clean bass anyways!
Feel free to correct me! I want to do this right the first time, but not go broke doing it!
The box will be 3.0 cu feet. It must be to get my desired sound out of my subs...
Thanks for the help!,
Daniel
http://kiztope.50megs.com
92 Rs 3.1/T-5
KYB Shocks and Struts, Blue Streak cap and rotor, neato new radiator!, RapidFire plugs
An overhead console!!
Clarion Head Unit,
Pioneer 6x9's,Cerwin Vega Plate 4x6's
Its slowly but surely coming along....
AIM : Theonekiztope
ICQ: 8787542
Planetarion: 3GFB kiztope of kiztopia-Camera-92RS-A (33:6:14(?))
"No one knows until they learn" Leon Calrinsky (99)
Old Jan 10, 2001 | 03:01 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Using 3/4" MDF, my sub box with 2 10s weighed 75 pounds.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6 Now Bilstein equipped!
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
Old Jan 10, 2001 | 08:34 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Ply wood sucks. If you can't get MDF, at least use particle board. In my area MDF is $35 a sheet, and many on here have said they get it for as little as $15 a sheet, so I wouldn't let cost deter you. My MDF dual 12" box has a total airspace of 3.0 cubic feet and weighs exactly 62lbs without any speakers in it. I haven't weighed a particle board box yet, but I would guess that it weighs in the range of 35 to 45lbs.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Jan 10, 2001 | 10:22 AM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
Where would you buy MDF? at the local hardware store? I'm gonna go check it out later on this week.
If I can get it cheap, I'll go for MDF, but otherwise, particle board is callin my name! If not for the lower price, for the weight savings and not having to buy new rear springs to hold the box!
Thanks,
Daniel
Old Jan 10, 2001 | 12:37 PM
Jim85IROC's Avatar
My hardware store doesn't keep it in stock, but can have it within a couple days. Just go early in the week and you'll have it by the weekend. For the sake of 15lbs, I'd reccomend the MDF. Not only is it better acoustically, it's MUCH better to work with. No chips splinters and rough edges. It cuts like butter.
The IROC Homepage
Old Jan 10, 2001 | 01:06 PM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
mine wighs 50lbs,just the box the particle wood is very thick,it is some kind of high density,not that flaky cheap ****, I'dont think it would affect suspension or speed performance too much,these cars are designed to carry a little extra wieght.you could compensate by keeping only one gallon of gas in the car at a time,but all that gas pumping would frustrate me after awhile.
Old Jan 10, 2001 | 01:12 PM
Home Depot, Loews, and Payless Cashways all stock 3/4" MDF in 4'x8' sheets. Bring a truck along ans because it self serve, bring a freind. Its not fun trying to load a 4x8' sheet by yourself
-Justin-
Old Jan 13, 2001 | 02:28 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
I think my tube weighs like five pounds, or something. Something to think about.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
Old Jan 13, 2001 | 10:52 AM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
Well, I have 2 Phoenix Gold 12's.... A box is the way to go!
My springs are by no means new. My car will more than likely sit a little lower, dont you think?
Thanks,
Daniel
Old Jan 13, 2001 | 10:00 PM
Superblue87Formula's Avatar
The back of my car sat a little lower w/ my dual 15 box in it, but I never weighed the thing (about 80-90 lbs, loaded) please get the MDF, you'll be much happier. I had a box I built out of high density fiberboard explode once, it wasn't pretty.. (this box had one 10 in it, was completely sealed, and totally blew up, it was neat !)
1987 Formula 350, headman hedders, Accel supercoil, cap, rotor.
MAF screens removed. 160 degree stat and manual fan switch.
Best ET: 14.745@91.317mph-Stock
Best ET: 14.418@95.51 mph-Modded
Ridiculed Founder of the Traction Impaired Crew
Old Jan 14, 2001 | 07:41 PM
Jza's Avatar
Jza
None of the hardware stores around here stock MDF. I had to go down to the industrial park and get it from a cabinetmaker supplier. $25 for a 4'x8' sheet.
Old Jan 14, 2001 | 08:41 PM
86V6's Avatar
Actually, I just finished my box today. 4.4 cubic ft. all MDF by itself is 74lbs. Holds 2 12", 30lbs each.... look at those for some real wieght. Total cost for box = sheet and a half of MDF, $36, remote terminal, $6, time 9hrs, 4 ports, $2... think about it. $42 and a friend can go a long way. Flushmounted from the back to the seats. ONLY USE MDF
Old Jan 14, 2001 | 10:31 PM
86FyrBrd's Avatar
Car: 1992 Camaro Z28 Convertible Z03
Engine: 383 SuperRam
Ok I feel a little emabrassed i think my sub box weighs more than anyones...with my subs mine is probobly 120lbs but that is 5/8 MDF with 2 Competition Ground Zero Nuclear series in which both weigh 40lbs each. My car still sits the same though.
86 Firebird, 305 4bbl, Flowmaster 80 series.
Sound System: Pioneer Head Unit, 2 Ground Zero 12" Nuclear Series Subs, Rockford Fosgate wiring, Crappy Amp untill July
Work to be done in July: New Engine (383 or bigger) New worked 700R4, power Sunroof, Trans Am Body Kit, Ram Air II hood, Rims, Tires, 1.5" lowering springs, and re-done interior...I want yellow and black but the 4th gen conversions look tempting, oh yeah painting it Yellow also
Old Jan 15, 2001 | 11:29 AM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
Thanks for the Info so far!
Hopefully I can get this done soon...
obviously MDF is the only way to go...
when I get the money together, Im gonna go find some..
Thanks,
Daniel
92 Rs 3.1/T-5
Clarion Head Unit,
AIM : Theonekiztope
ICQ: 8787542
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Ed1LE
Sep 30, 2018 09:14 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Zell1luk
Sep 29, 2015 10:36 AM
