what is gain
Old Jan 19, 2001 | 02:21 PM
STL1994's Avatar
what is gain
i never really understood what it was, what does it do and where should it be set?
Old Jan 19, 2001 | 02:37 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
The gain control on an amp is basically a volume control for the input signal of the amp. The gain is used to attenuate that incoming signal to the point where the maximum undistorted output of the deck will allow the amp to produce it's maximum undistorted output. If it's turned down any lower, the amp won't make it's full power, and if it's higher, the amp isn't achieving it's best signal to noise ratio. When you feed a high voltage input to the amp, you can turn the gain down which will also move the noise floor of the amp down, giving a better signal-noise ratio.
Generally, the gain of the bass amplifier is set up this way, and the gain on the other amp(s) is used to match the levels appropriately. In a higher-end system where you have line drivers and other processors, sometimes they are used for signal matching, and each amp gain is adjusted individually for maximum signal-noise ratio.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Jan 19, 2001 | 04:52 PM
STL1994's Avatar
wow, i actually understand now. thanks!
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
antman89iroc
36
Jan 31, 2016 08:42 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
IROCThe5.7L
Sep 17, 2015 07:48 AM
