GTA Stereo Problems... HELP!
Old Jan 15, 2001 | 10:29 PM
B L A D E's Avatar
I just bought a nice 89 GTA.. the guy pulled his headunit, and gave me the GTA stock one. I spliced the harnesses back in, but am missing ONE... the one that the orange and ?brown? wires go into... and my steering wheel WONT unlock the headunit.. PLEASE HELP I NEED MUSIC AND HAVE NO MONEY!!!!!!
No, seriously, help me!
Old Jan 15, 2001 | 10:32 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
There's a separate plug for the orange and brown. The orange is either battery or ignition, and the brown I believe is the dash light dimmer.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Jan 15, 2001 | 10:34 PM
B L A D E's Avatar
Well, why wont the headunit unlock when I push mute?!?! Is there something else I need to do?? Check?? HELP!!!!!!!!!!!
Old Jan 16, 2001 | 11:16 PM
B L A D E's Avatar
PLEASE HELP ME!
<----- Quickly going insane
Old Jan 17, 2001 | 12:01 AM
Chris Luongo's Avatar
Forget about unlocking...the thing shouldn't even turn on at all unless that orange wire's hooked up.
Old Jan 17, 2001 | 12:30 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Yeah, make sure all wires are hooked up. Once everything is hooked up, try unlocking the deck with the mute button. If that doesnt do anything, double check and make sure all your wires a re-spliced correctly. If everyhting is hooked up right and it still doesnt work, the steering wheel controls or just the mute button might be messed up. Try cleaning the contacts out underneath the button if possible or use a can of contact cleaner on it.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
Old Jan 17, 2001 | 02:23 AM
B L A D E's Avatar
OK... So I gotta hook them all up... the ONE opening left in the rear of the head unit has TWO pins in it (for TWO wires) they are numbered one and five... can someone tell me which wire goes where? PLEASE?!?!
Thanks guys!
Old Jan 17, 2001 | 08:06 AM
Jim85IROC's Avatar
Shouldn't that be the one for the 2 wire plug with the Orange and brown wires you were wondering about? The other 3 harness sections all have multiple wires.
The IROC Homepage
Old Jan 17, 2001 | 04:13 PM
dude12387's Avatar
ok, heres how i remember mine, the last harness your talking about(with about 4 wirees??) is the remote for the steering wheel, without that hooked up, it wont work....
"When something breaks, it gives me an excuse to replace it with a performace part!"
1988 GTA
TES headers
Flowmaster exaust
TB airfoil
165 Tstat
K+N's
JET chip
kenwood head unit, xplod amp, poineer 3 ways
weird rattling noises
dying 350
crappy paint
700R4 on its last leg
hood that won't open
Old Jan 17, 2001 | 08:06 PM
B L A D E's Avatar
The last harness only has TWO wires for it.. I dont have ther harness itself, but the two pins in the rear of the radio, and the two wires that are supposed to go into it... which goes where?!
Thanks guys...
Old Jan 18, 2001 | 07:46 PM
Just go back to the junkyard and get that harness and do it right.
One of those wires is for illumination (brown), and the other is for constant power (orange). You won't do any damage if you hook them up backward by mistake.
If the backlighting is constantly on, and the radio will only turn on if you switch on the parking lights first....then you have the two wires backward.
Old Jan 21, 2001 | 12:00 AM
turbo497's Avatar
look at this link it explains how the system works. http://www.geocities.com/motorcity/1500/swc1.htm
the orange wire is a 5 volt data path from the controller and is NOT for lumination. I think orange should go to pin 5 the other is black and is ground (look through the holes on the side of the radio you should see the wires inside) PAC makes a module for the interface and may have addtional info on the web site
3.8 turbo 20th anniversary transam #497 first owed by Clifford Williams, Bass player from rock band AC/DC
HP52TA
Feb 3, 2018 10:51 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
1992Z28!
Nov 19, 2015 07:33 AM
okfoz
Sep 15, 2015 05:22 PM
scottmoyer
Sep 7, 2015 07:06 PM
