Which is pos/neg? A or B?? Also, Connections? w/in
Old Jan 19, 2001 | 11:29 PM
MINT1982CFI's Avatar
Hello all,
I just got a set of Pioneer 6x9 3 ways for the rears, and I need to know 2 simple things:
the factory harness says only A & B - is that A for pos and B for neg??? Seems simple enough! is it right?
Also, how do I determine which is pos and neg off the speaker (no box/instructions.) one is BIG, one terminal Is SMALL.
Any help GREATLY appreciated
Thanks in advance!
Old Jan 21, 2001 | 01:08 AM
XxMoLexX's Avatar
trial and error, wont hurt the speakers. jus make them sound distorted. I think a = pos and the big one i tink would be poss but i could be rong..
91 3.1 RS.
T-Tops
12" tube in the trunk
16" ROH Rims (Need Center Caps) ROH Rims
Firehawks all Around
Old Jan 21, 2001 | 03:22 AM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
yea, on pioneers, the big terminal is the positive and the small is the negative. i dunno about the A & B thing.
Stock 2.8 MPFI auto w/ Flowmaster 40, More to come......
New Pioneer Head Unit
2x 10" Thruster Subs powered by 300 Watt Jensen amp
More to come..... (hey, i dont got a job yet)
Old Jan 21, 2001 | 12:44 PM
OLDYELLR's Avatar
Car: '85 IROC
If you have the pos/neg reversed from what the front speakers are, they will be out of phase. By leaning back and forth you will only be able to hear either the front or rear speakers because they will be cancelling each other out. When they are in phase, there will be more volume and they will blend front to back.
1985 Yellow IROC-Z 5.0 HO, T-5 3.73 Posi, 4 wheel disks
PFCM pads, GTA wheels, Koni yellows, B&M Ripper, Dynomax
Old Jan 21, 2001 | 11:54 PM
Chris Luongo's Avatar
Just go to a car audio shop and pay $5 for a speaker harness adapter. This way, you won't have to cut up your car's wires, which saves a lot of time and mess. You simply snap this adapter into your factory speaker plugs, and the other end slips onto your new speakers.
On virtually any car speaker, including your Pioneers, the larger terminal is positive and the smaller is negative. If you look at that white cardboard-like piece very closely, the terminals are marked + and -.
Your factory wire colors are this:
Right rear: dark blue-positve
light blue-negative
Left rear: brown-positive
yellow-negative
But still, like I said, go buy one of those speaker harnesses.
InfernalVortex
Apr 20, 2021 11:31 AM
bplessy
Sep 30, 2015 12:14 PM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
