Help Quick Please!
Old Jan 4, 2002 | 10:03 PM
88TAJeff's Avatar
Car: 88 T/A
Help Quick Please!
Help, I'm hooking up a friends Soundstream 700SX to his Kappa 12.1, and I need to know how to bridge it to mono. It didn't come with a book. Do I hook up L-, and R+, or the other way around?
We're in the process of connecting it now
PLEASE HELP QUICK!!!!!!
Thanks alot,
Jeff
Old Jan 4, 2002 | 10:44 PM
Flash84Z28's Avatar
Car: '03 S-10/ '87 Trans Am
Engine: mild 350
Transmission: TH350
Doesn't the sub have a "BRIDGE" with arrows pointing to the correct posts? I'd try it the other way around R = - and L = +. Details are always welcome though...is the sub DVC? Stereo amp? Four channel? Sometimes we can spot something you missed that could save time and trouble.
Hope this helps,
Matt
Old Jan 4, 2002 | 10:48 PM
88TAJeff's Avatar
Car: 88 T/A
Thanks, Flash,
I know, usually amps are marked, this one isn't. Just a regular 4 ohm 12.1. , and the Amp is a 2 channel "bridgeable" amp.
Old Jan 4, 2002 | 11:03 PM
MotoGod's Avatar
There might be a switch to set the amp to run in bridged mode as well...look around for one.....if not...just fiddle with the channels. If it's bridgeable...one of the combos should work ;-)
Old Jan 4, 2002 | 11:23 PM
88TAJeff's Avatar
Car: 88 T/A
Thanks guys,
Got it working. It was R+, L-; the other way around wasn't nearly as loud.
Old Jan 5, 2002 | 11:40 PM
87transam5.7tpi's Avatar
is the sub a 2 ohm? if it is make sure your amp can support 2 ohm bridged. dont' wanna burn up the amp :-(
Old Jan 6, 2002 | 01:21 AM
88TAJeff's Avatar
Car: 88 T/A
Hi 87,
no, its just a single 4 ohm voice coil. It's in a truck, and I'm surprised in the difference in bass without that "cabin gain".
I'm running 2- 8" tubes and 1 JBL600.1 in my car with about 4 times the amount of bass.
F-body-fan
Jan 12, 2023 01:49 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
3.8TransAM
Sep 27, 2015 08:37 PM
