multi-amp system
Old Feb 14, 2001 | 06:51 PM
shopteach's Avatar
multi-amp system
Ok, I've tried this before but had problems. I'm wanting to hook up 4 JL audio 10" ws6 subs, and a pair of pioneer 3 way 6-9's. I already own these speakers, and a 70 watt by 2 pioneer amp. I did this before but the amp I bought was a cheap piece of **** and didn't work. So, I was planning to run 4 gauge wire to a power distribution block. Then run 4 gauge to the larger amp I'm going to buy for the subs (Planing on a rockford fosgate amp about 600 watts), and 10 gauge to the pioneer amp for the 6 by 9's. The back speaker wires are already hooked up to a line converter. The distribtion block is already in the car. I know to use the same gauge of ground wire as I do power wire. Also a 70 amp fuse block is currently installed in my car for just this purpose.
Can anyone tell me any problems I might run into? Any tips would also be nice. When that cheap amp was working for a short time everything sounded ****ty. Was it just a power problem(only ran 8 gauge that time)or is there a trick to hooking up more than 1 amp to a car. I have heard you sould run seperate power wires for each amp, but this seams unnecessary to me. I think one 4 gauge will be enough.
Old Feb 14, 2001 | 07:42 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I can only forsee 2 potential issues. The first is that you're using a speaker level signal with a LOC (Line Output Converter). I'm guessing that you're doing this because you've got the stock deck. The stock deck has a horrible frequency response, and is not at all smooth in the bass region. Those W6 subs are good subs but will not sound good using a signal from the stock deck.
The other problem is that 4 W6 subs are going to give you a 3 ohm load. This shouldn't really be a problem for a Rockford amp, but the amp WILL run a tad hot, so you're going to have to take that into consideration when mounting it.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Feb 15, 2001 | 07:02 AM
shopteach's Avatar
actually I have a Pioneer cd player in the car. I ran the line converter because at first I did have the stock cd player. Is it really worth it to run the RCA jacks?
Old Feb 15, 2001 | 09:14 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
First, definately run the rca's. Run them on one side of the car, and the power wire on the other side. Which brings me to:
Second, if you run a 4 guage to the dist. block, then it would be pointless for you to run a 4 guage to the bigger amp, and an 8 guage to the smaller amp. It won't matter, it's just that you should only need to run an 8 guage to both. But if you were to purposefully run an 8 and a 4 guage after the block, your input cable should be no smaller than 2guage. Once again, not needed.
Third, I don't know too much on the specs of JL, but I thought that the WS6 was a 6 Ohm speaker? If so, you can run two in series, and then parallel that to get you a 6 Ohm load, or if you run two in parallel then series that you will also get a 6 Ohm load. But if you parallel, then parallel, you'll end up with a 1.5 Ohm load. With a Fosgate, you'll be running hot, but if you get the higher up models, then you'll be fine. Just make sure that you keep air moving over it.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
Old Feb 15, 2001 | 10:36 AM
shopteach's Avatar
ok, I'm new to this advanced stereo stuff. What do people mean by running in parallel?
Old Feb 15, 2001 | 12:22 PM
Jim85IROC's Avatar
http://www.jlaudio.com/tutorials/wiring/2dvc.html
The IROC Homepage
Pac J
May 17, 2020 10:44 AM
jrdturbo
Mar 31, 2016 02:58 PM
1992Z28!
Nov 19, 2015 07:33 AM
Night rider327
Oct 9, 2015 09:25 AM
Night rider327
Sep 25, 2015 04:47 AM
