Bandpass Question
Old Jan 8, 2002 | 03:26 PM
1986CamaroSC's Avatar
Car: 1986 Camaro SC
Bandpass Question
Will taking the plexigalss off of my bandpass make the subs sound weird?
Old Jan 8, 2002 | 05:52 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Very. Why don't you try it and report back to us.
Old Jan 9, 2002 | 12:06 AM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
jim is right. a bandpass box consists of a ported enclosure on one side of the sub and a sealed enclosure on the other. buy removing that plexi, you've just eliminated one of the enclosures. i'd say ditch the bandpass altogether for a sealed box, but thats my opinion (very SQ biased). let us know how the box sounds.
Old Jan 9, 2002 | 05:09 PM
Mike92RS's Avatar
It'll sound like a severly undersized ported box.
- Mike
Old Jan 10, 2002 | 06:28 PM
Car: 1986 Camaro SC
yeah, i was reading up on bandpasses, and diecided not to take off the plexi,
but the *$#in idiot who sent them to me didn't wrap it up or anything and now theres a big crack in the plexi, Anyone know how i can fix it or get some more plexi for it>???
Old Jan 10, 2002 | 06:37 PM
jobryan26's Avatar
local glass shop. Just take in your old and say I need one just like this.
Old Jan 10, 2002 | 08:15 PM
Car: 1986 Camaro SC
will it be very expensive? it has a big bend in it, it's like a 90 degree bend on the edge
Old Jan 10, 2002 | 10:02 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
flat plexi is realy cheap, i bought some to mount my rear speakers in. however, i dont think bending is cheap and not easy to do. i broke quite a bit of the stuff while just cutting it, must be very patient. not too sure where you'd find a place to get it bent either. maybe get two pieces and bond/glue them together?
Old Jan 10, 2002 | 10:11 PM
jobryan26's Avatar
That part i don't know. I bought a 1/8" 10"x24" I think it was for like $8 or so but you'd need plexi alot thicker than that. As for the curve issue I remember seeing how Hot Rodders make their own custom turn signals and lens. To make the lens they took wood and shaped it to the fit they were looking for and took a part of a turn signal from a junked car and cut it to the size of the of their mold. Then they laid the lens onto of the mold and then they stuck it into the oven(yep they showed the one in their house!) with it on like 325degrees. The lens softened up and laid to the shape of the mold. It was only in there for like 1 1/2-2minutes. Pulled it out and let it cool and there was their new lens for their turn signal. The reason I'm blabbing about all this is because you might have to form the plexi if there's much of a curve to it. Plexi cracks really easy if it's put into much of a bind. Depending on how thick the plexi is would depend on the amount and length of heat if needed. I would just go and talk to the glass shop and then go from there.
Old Jan 10, 2002 | 11:27 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
"Just without the crack in it please."
HEHE!!!!!
Sorry John. I just had to do it.
AJ
Old Jan 14, 2002 | 02:08 PM
custman87T/A's Avatar
I have cut plexi before...while it is not easy it isn't havrd either. Cut the plexi to gross size....run it over a table saw where you want the bend with the blade almost completely down to just score it with the blade....then heat and bend slowly or it will break. I have done this many times with many different thidcknesses of plexi.
fasteddi
Sep 10, 2015 09:32 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
