Hello, I am wondering if my alternator, and or battery will be affected. I just purchased a power acoustik 2200 watt amp, 500 x 2 @ 4 ohms
850 x 2 @ 2 ohms and
bridged mono max it is 2200 watts.
I was wondering if i was running 500 x 2 at 4 ohms with 2 12" mtx 8000 subs will my stock alternator and slightly better than stock battery hold up. My friend doesn't think it will but I think it should be ok. Help will be great. Thanx
Jason
Jason
It'll be just fine, just dont run it to long with the car off
LS1 Killer!
Jeremy
1989 Firebird Formula L98 350
BBK 52mm TB
Edelbrock headers and 3" Cat-back Flowmaster
K&N cone filter
Free mods
MSD/Taylor ignition
Jet AFPR
150 shot NOS
Kenny Brown subframes
Hotchkis lower control arms, panhard and strut tower brace.
Eibach Pro-kit springs
Polygraphie bushings
Monroe SensoTrac shocks/struts
12.63@109.95 NOS
14.40@95.28 motor
L98Formula@yahoo.com
LS1 Killer!
Jeremy
BBK 52mm TB
K&N cone filter
Free mods
MSD/Taylor ignition
Jet AFPR
150 shot NOS
12.63@109.95 NOS
14.40@95.28 motor
Jim85IROC
close
What size fuse does the amp have on it?
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
The IROC Homepage
83CAMAROMAN
close
- Join DateFeb 2001
- LocationPORT RICHEY, FLORIDA
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Car1983 Camaro Sport Coupe
- Engine1986 305 C.I.D. Bored .030 over
- TransmissionTH350 W/Shift Kit
- Axle/Gears3:08
- Liked:0 Times in 0 Posts
yeah it all depends on the amps that the amplifier pulls if its more that the alternator can handle then you have a problem in my 83 i had a 75 amp alternator and two 1600 watt profle amps running 2 orion 12's well i knew i was having problems when a long bass hit would come and my headlighjt would shut off as i was driving, the amps were pullin over 60 amps each
sounded good though
1983 CHEVROLET CAMARO with a 1986
305 C.I.D.V8 BORED .030 OVER
HIGH VOLUME OIL PUMP
FLAT-TOP PISTONS
MILD CAM
3" CAT BACK EXHAUST W/ FLOWMASTER MUFFFLER
KEYSTONE CLASSIC WHEELS.
B&M RATCHET SHIFTER
STAGE THREE SHIFT KIT
(she'll spin em into third)
MUSTANGS SUCK
sounded good though
FLAT-TOP PISTONS
MILD CAM
B&M RATCHET SHIFTER
MUSTANGS SUCK
Well in my 91, I had a Kenwood 300x1 amp bridged to a pair of 12" Rockfords...... It sounded bad *** , BUT it killed my alternator and battery........ Now my car is still weak?? If I was you, I would go ahead and beaf up that alternator. It wouldn't hurt anyway..............
I suspect your friend is correct the stock alternator is not going to last very long especially if its not new. as the previous post mentioned, what is total amps on the fuses on the power acoustik amp?
If you are considering buying a HO alternator make sure you get output specs at low rpm. Typically, the output advertised is at 1,000+ rpms which doesnt help much sitting at a stoplight in the middle of august with the lights on, A/C running, etc.
As a point of reference, I run a Kicker ZR600 amp (3 X 30 amp fuses) and a Kicker Impulse amp off a new 100 amp AC Delco alternator, new Sears DieHard Gold battery and a 1 Farad CAP. No problems after 7 months, ie, lights dimming, etc.
This setup fried the alternator that was on the car when I bought it (10/99), but I suspect this was the original alternator since the car (1991 Camaro) had only 27,000 miles plus the owner had put a cheap battery in the car.
HTH
HTH
I used to have this amp, it was 3x35Amp fuses IIRC... I don't think the amp really put out 500x2 at 4 ohms, or 850x2 at 2 ohms or whatever, but it is huge (24.5" long) and looks freakin awesome! It's a good amp though, I beat the hell out of mine for a couple years. You will probably want to add a capacitor, a stronger battery, and almost definitely a bigger alternator. At night with your headlights on, when you hit the hard bass, you will probably be putting a 100+ amp load on your charging system. Maybe look into a 140 amp alternator, or even a stock style 105 amp from a later 3rdgen..
I run a 160amp alternator from Power-Line. It is externally regulated and adjustable.
They rate the current flow hot, so it puts out closer to 200 amps cold.
Ran it since 1993 & no problems ever.
