bridging
Old Feb 24, 2001 | 03:51 AM
v6-3.1's Avatar
bridging
I have a sherwood amp that is 100 watts RMS, when bridged it rates 250 watts RMS. am I better off getting a dual voice coil sub or just bridging a single coil sub.
Old Feb 24, 2001 | 05:59 AM
racer J's Avatar
Car: 1992 Chevrolet RS Camaro
Engine: 305 TBI
Transmission: WC T5 conversion
Axle/Gears: Debatable . . .
Chances are your shearwood amp's power rating is bridged @ 4 ohms. So just get a single voice coil sub. The only reason to get a dvc sub is so you can run a 1 ohm bridged load with two subs instead of four or if you have a sun that can handle the power that an amp puts out at a 2 ohm load. You have to hook up all the voice coils in order to acheive these loads though.
1988 Camaro
305 bored .030 over
Stock TBI
Aluminum radiator
No smog pump
gutted factor cleaner
cam ground to crane specs
timing advanced 9 degrees
no thermostat
other than that its bone stock and ran a 16.4 @ 82 mph with earth shattering wheel hop and a 2.88 60 ft time. (this was with the rebuild and cam only)
Old Feb 24, 2001 | 10:07 AM
The ODB's Avatar
bridge the single
Old Feb 24, 2001 | 03:43 PM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
I have a Sherwood crossover, and it's pretty cool, but I don't think that it's too high quality.
With the lower quality stuff, you never want to run more than one sub if you're gonna bridge, because the THD level will be too high. And the amp will work twices as hard just to make enough power. You can get a louder cleaner sound with just one sub.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
CD MaroMan 91
Car Audio
Sep 1, 2001 12:27 PM
89Firebird Formula350
Car Audio
Aug 30, 2001 06:41 AM
TrueBlue91RS
Car Audio
Aug 18, 2001 11:58 PM
TrueBlue91RS
Car Audio
Aug 14, 2001 07:30 AM
Tom 400 CFI
Car Audio
Apr 29, 2001 01:48 PM
