6x9s: 2way 3way compatibility question
Are the stock 6x9s 2 or 3 ways? (i haven't looked in a while) whichever they are, do you have to replace them with the same thing? ex: if you have 2 ways, can you just plug in 3 ways without changing anything else?
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Stock speakers are neither. They are 1 way. One driver for the entire frequency range. You can use 2 ways, 3 ways, whatever. It is all 100% compatible. Just make sure to listen to the speaker and if you like how it sounds, go for it.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
The IROC Homepage
according to what criteria? I can find 4 ways at a flea market that sound like a monkey banging on a drum, and I can find Boston CX 2 ways that sound very, very good. The number of drivers doesn't mean much. If anything, a speaker with more drivers can very easily sound worse because if the multiple drivers are not tonally matched and used with very high quality crossovers, it results in a very poor sound. Most speakers that use more than 2 drivers, or sometimes 3, are usually cheap speakers that are just adding more crap for the sake of marketing or the "Bells & Whistles" effect.
The IROC Homepage
The IROC Homepage
If you can't get good quality sound from two drivers (i.e. 2 way 6x9) then there is something wrong with the design of the speaker itself.
Look at a 3 way speaker. The two that are over the main cone are generally not that much different in size. Maybe .5" or so difference?
If you can't get the highs you need from one tweeter, what makes you think the other is going to help that much more? (Bah to super tweeters, nonsense garbage)
Besides, the more crap you put on a bridge over the main cone, the more midrange output you are blocking by obstructing the speaker.
Carl
Carl
