racerJ -------------> Boston Pro Subs
Old Feb 27, 2001 | 04:13 PM
IROCET's Avatar
Car: 88 IROC-Z (Sold)
Engine: 5.7L
racerJ-
I saw your post about the Boston Pro Series subs that I just bought. The ones that I got are 12" model 12.5LF. Those come in 2 and 4 ohm, I have the 2 ohm model. The specs for the 12's in 2 ohm trim are:
Recommended Power: 50-1200 watts
Mounting Depth (F): 5 5/8"
Box Volume (int): 1.0ft3
Cone Area (Sd): 510cm2
Voice Coil Dia: 51mm
Max Excursion: 40mm (Peak to Peak)
Ref. Efficiency: 0.46
Moving Mass: 121g
I think that these subs are great. It is almost impossible to over power them. They like power. I talked to boston techs before I bought them, and they told me to make sure that I don't run them in parallel off of my amp for too long or it will hurt it. I can't wait to get my box built, cause they will only sound better.
If you don't want 12's, they also make 10's MN: 10.5LF (2 & 4 ohm) and 8's MN: 8.5LF (2 & 4 ohm). Boston make about the best speakers in my opinion. They are extremely clear, and have very good sound and build quality. Let me know if you have any other questions. Their website is www.bostonacoustics.com You should be able to find out everything there. Later
Matt
irocet@hotmail.com
drive.to/Stang_Kilr
88 IROC-Z -- 350 L-98, 700R4, Flowmaster, K&N, MAF Sceens Gone, Airfoil, March Pullies, Comp Cams Magnum 1.6 Roller Rockers, Accel U-Groove Plugs, Accel 8.8 mm Wires, Hypertech Cap & Coil, Hypertech Chip, Hotchkis Strut Tower Brace, One Loud Stereo!
Old Feb 27, 2001 | 09:37 PM
racer J's Avatar
Car: 1992 Chevrolet RS Camaro
Engine: 305 TBI
Transmission: WC T5 conversion
Axle/Gears: Debatable . . .
LOL those aren't subs those are power distribution centers if they can take 1200 watts RMS. I'm really going to have to check into those subs if they handle power like that. I've always heard they had great mids and highs but I never heard anything about their subs till now. Thanks for replying to my post in your post. It was kinda cool getting a post with my name in the subject line too.
1988 Camaro
305 bored .030 over
Stock TBI
Aluminum radiator
No smog pump
gutted factor cleaner
cam ground to crane specs
timing advanced 9 degrees
no thermostat
other than that its bone stock and ran a 16.4 @ 82 mph with earth shattering wheel hop and a 2.88 60 ft time. (this was with the rebuild and cam only)
Old Feb 28, 2001 | 10:41 AM
IROCET's Avatar
Engine: 5.7L
Well, I'm glad you are proud to see your name on a post! lol Up here in Columbus, Ohio, there is only one or two places to get them. I'm sure there is a place down there around Dallas that would carry them also. I think that Boston has a dealer finder on their website.
Yeah, they can handle some serious power. The guys at Columbus Car Audio said that when they were originally tested, the amp they were using blew before the subs were even working very hard!
I did have to wait a while to get mine. They were having trouble getting them in stock, but once they were here they gave me a pretty good discount. Good luck, and hopefully you can find a shop with them on display.
Matt
irocet@hotmail.com
drive.to/Stang_Kilr
Old Feb 28, 2001 | 07:30 PM
racer J's Avatar
Engine: 305 TBI
Thanks again for replying. I'm sure Earmark, a high performance stereo shop, sells them. I know someone does because we had a car come through BMW when I worked there back in 97 that was loaded down with the subs and the mids and highs in their packages in the trunk. I can't wait to hear them. I'll probably use three of them and put an Autotek super sport amp on each one to give them about 800-900 watts each
1988 Camaro
305 bored .030 over
Stock TBI
Aluminum radiator
No smog pump
no thermostat
Old Feb 28, 2001 | 10:31 PM
IROCET's Avatar
Engine: 5.7L
I almost bought an Autotek amp a year ago. The thing was huge, and put out way too much power for my two tens that I had at the time. The one that you are going to use puts out what kind of power? What kind of ohms will you be running them at?
Matt
irocet@hotmail.com
drive.to/Stang_Kilr
Old Mar 2, 2001 | 01:46 AM
racer J's Avatar
Engine: 305 TBI
I beleive the amp puts out 500 watts rms @ a 4 ohm load and 600 watts rms @ a 2 ohm load. I think the model number was SS500.2
I do know that it is an Autotek Super Sport series amp. I'm worried about the current draw though because it says it can draw a max or 39 amps and, if I use three of these amps as well as a smaller model, a SS300.2, for the mids and highs I could need to draw 236 amps at any given time if they all draw their max amps at the same time. I was thinking about adding on an Optima battery with a battery regulator as well as (2) 1.5 farrad caps to solve this possible delima. I may go with a bigger amp though like the SS800.2 to give them 800 watts rms @ 4 ohms or 900 watts rms @ 2 ohms. I just thought giving each sub its own amp would allow full power to each sub as well as custom tunning. Not to mention a sweet look when on display having four amps in the rack.
1988 Camaro
305 bored .030 over
Stock TBI
Aluminum radiator
No smog pump
no thermostat
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
91 SrS
Oct 7, 2015 04:32 PM
meeklay812
Oct 1, 2015 03:46 PM
raymondandretti
Sep 27, 2015 06:43 PM
efiguy
Sep 27, 2015 01:30 PM
