I got a question about amps.
Old Jan 11, 2002 | 09:11 PM
DiecastZ28's Avatar
I have the amp wire off the battery right to the amp. When I turn my car off will the amp drain the battery because its a straight connection? Or when its off it breaks the connection?
Old Jan 11, 2002 | 10:12 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Where's the Remote wire? Did you hook it to the head unit?
If you did, and the HU is off, then it'll be fine.
You do have a fuse in the power wire from the batt to the amp right?
AJ
Old Jan 11, 2002 | 10:27 PM
Flash84Z28's Avatar
Car: '03 S-10/ '87 Trans Am
Engine: mild 350
Transmission: TH350
Yeah, I hope you have a fuse, preferably near the battery.
-Matt
Old Jan 12, 2002 | 01:23 AM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
if the remote wire is attached to the head unit, it wont. the remote wire tells the amp to turn on or off, depending on if the radio is on or off. i agree with the other guys, you better have a fuse on there (preferably within 18" of the battery)
Old Jan 18, 2002 | 03:57 PM
DiecastZ28's Avatar
Ok, I under stand now. Ya i do have a fuse on the amp wire right in front of the battery.
fasteddi
Sep 10, 2015 09:32 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
