Power antenae on 87' T/A
Car: 2KGTP
Engine: supercharged 3800 L67
Transmission: 4T65E
Axle/Gears: 2.93
The motor on my T/A's power antenae is busted. It is stuck on, even when I shut the car off. This means I have to pull the fuse or it will wear the battery down and I lose a few of my accessories. I took a quick look to see if I could disconnect it somehow or remove it, I had no luck. It can't tell but either the fender or the panel in the wheel well has to be removed in order to access it.
Can you guys tell me how to get to this thing? Is there something I can do in the mean time to stop it without having to pull the fuse every time I shut the car off?
1986 CAMARO Z28 ->
151,000 original miles, 43,000 on 89' vette 350 block, Holley 650 DP, Weiand intake, 1.6 rockers, 1 5/8" headers, no cat, 2 1/2" Flowmaster catback, Mallory coil, March pulleys, T5 with 3.35 1st gear and 0 miles, 90% Centerforce clutch, 3.73 posi, Eibach 1" drop springs, Spohn LCA's, Spohn adjustable panhard rod, Subframe connectors, polyurethane swaybar bushings/endlinks, 2 12" Sound Streams, 2 Infinity 6X9's, 2 Pioneer 6X9's, 800 watt Lanzar Vibe amp. ET 13.22@ 106.4MPH 3300lbs less driver and speakers Next mods-> B&M shifter, Extreme Energy 268 cam, Holley street dom intake.
1987 TRANS AM ->
73,000 miles, 305TPI, auto, all stock.
1986 CAMARO Z28 ->
1987 TRANS AM ->
Car: 88 GTA
Hey, to get to the antenna you have to take your wheel off, take the black plastic well thing out (4 screws and 10 clips I believe), then if you wanna take it out, u need to take off the gfx and unbolt the fender at the bottom and tilt it to pull the antenna out or you can just cut the wires.
Later,
Dave
1987 Pontiac Trans Am GTA
5.0, Auto, T-Top, Digital Dash, etc
http://www.fbody.com/members/1987GTA/
Later,
Dave
Are there any "Powered" antennas that will go INSIDE of the fender for a shaved look but better, or as good reception?
Thnx
91 FireBird 305 V-8
no true mods,
ghetto rigged cold air intake,
People dont have a soul, its just something parents made up to frighten little children, like the boogie man, or micheal jackson..."
GheTTo Riggers INC.
We Make Mcgyver look Like Crap
Thnx
91 FireBird 305 V-8
no true mods,
GheTTo Riggers INC.
I have the same problem w/ mine but i jusy left it up and unplugged it...the plug is behind the plastic piece under the "glovebox" where it had the performance suspension badge. The rest is from memory so dont quote me on this. Remove that and there will be two plugs on the left and i think the top one is the one you want. Just havve your antenna running and pull each one until you find the right one. I've had mine unpluggged for about a year now....i guess i'm too lazy to replace it.
Car: 2KGTP
Transmission: 4T65E
Axle/Gears: 2.93
I guess I could do that. Kinda sucks though, I get free automatic car washes. No more until I get a regular antenae, I guess.
1986 CAMARO Z28 ->
1987 TRANS AM ->
1986 CAMARO Z28 ->
1987 TRANS AM ->
sailtexas186548
Aug 24, 2015 10:11 PM
