84 Trans Am with uq7
Car: 1984 Trans Am 5.0 HO
Engine: 383
Axle/Gears: Dana 44 4.09
I have an 84 Trans Am with the UQ7 and I need to replace the speakers , the 5 inch subwoofers are shot. I was going to replace the foam rings, but one of them has an ohm reading of 2.4K ohms and the other is 10 ohms.
I have pulled the front and rear speakers , the fronts are around 8 ohms and the rears are around 4 ohms.Can anyone confirm that this is correct?
The front and rear 4x6 speakers have different part numbers stamped on them.
by https://www.flickr.com/photos/gary-chalker/, on Flickr
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: 84 Trans Am with uq7
You can get some good info from this thread about the UQ7 set-up. I think it's mostly the 85+ cars,.. but some of the info might help !
https://www.thirdgen.org/forums/car-...ments-uq7.html
