Remember the Kicker SSCTF
Old Oct 24, 2001 | 04:36 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Hey all I have been looking for one of the old Kicker CTF full range boxes for a long time. Does anybody know where I may find a used one since they don't make them anymore.....
Brian Felts
1989 Camaro RS
305 .030 over Hydro Pistons
Vortech heads milled to 58cc...Performer RPM intake....LT4 cam..Crane Gold rockers...FastChip custom chip...ALum. Driveshaft...3.73 gears with Posi...underdrive pullys...Rebuilt 700R4 with Vette Servo and B&M shift Kit...MSD ignition...A/C Delete No SMOG junk....1997 SS leather interior...B&M Shifter... Ultimate TBI mods...14X3 K&N open Element Non-Drop...Hooker headers....3" exhaust with Flowmaster Cross flow 16X8 Wheels from 97 RS Spohn LCA's Spohn Panhard Bar..LETS PLAY FORD!!
www.geocities.com/feltsb
Old Oct 24, 2001 | 05:10 PM
Polecat's Avatar
I remember it, late 80's.Of course I've been here that long.........I might know where a cabinet is. Let me see tonight.
Old Oct 24, 2001 | 10:27 PM
OldOneEye's Avatar
Car: 1997 Nissan 200SX SE-R
Engine: 2.0 Liter SR20DE
Transmission: 5 Speed
Why would you want to have a full range box?
Juan
Old Oct 25, 2001 | 06:09 PM
XxInFaxX's Avatar
try something like an ebay auction or something like that
Old Oct 25, 2001 | 06:13 PM
Yeah I did try the E-bay but had no luck......As to the reasion I would like to have one is......they are a great way to have a one amp full range system and they also provided great sound. Granted they will not compete with what most have here ( I do envy the talent you guys have) but I just liked them
Brian
1989 Camaro RS
Old Oct 25, 2001 | 09:07 PM
OldOneEye's Avatar
Brian,
I hate to break it to you but your car will end up sounding like a loud 6 x 9 at the most.
Having all that sound coming from the back is like listening to a concert from the lobby. Sure the sound gets to you, but it bounces off stuff.
Plus, the fact the ones you'll find will be so old and be heavy, after shipping you might not have found that good of a deal for somewhat small return.
Juan
Old Oct 25, 2001 | 11:24 PM
jobryan26's Avatar
CTF was about '87 or '88 I'm thinking '88
See my Ride:
https://www.thirdgen.org/rides/index...ew&rideid=1324
Old Oct 26, 2001 | 09:57 AM
Polecat's Avatar
<font face="Verdana, Arial" size="2">Originally posted by jobryan26:
</font>
actually loner. Introduced as a CTF, then moved to an SSCTF 2 years later.
Old Oct 26, 2001 | 01:54 PM
David Petersen's Avatar
I used to have an SSCTF and I LOVED the sound that came from it. I replaced my 12" subs in a flat board with the box and it sounded better and louder with the 10" beacuse of the design. The box was angled so the sound would bounce off the back window an come directly at you and it worked!!! I hope the nay-saying comments were coming from expericence and not just theory.
My box actulally broke so I had a custom lighter one made just like the old one. Sadly the car I was restoring and the box built for had a bad frame. If you would like the box I have I will sell it to you cheep. All I have is the box and the hardware no speakers. David.Petersen@IGT.com
Old Oct 28, 2001 | 12:18 AM
OldOneEye's Avatar
David,
Theory? Sure. But I know what having lots of sound coming from the back of the car, and even if you like it, doesn't mean its realistic. People are going for the bass up front, not the highs and bass from the rear effect lately. I do think it could sound good, but sound in front is better and more realistic (the stereo image is more realistic, with all those drivers so close in the rear and you so far away, it sounds like sound is coming from the rear, not from the rear right and rear left).
I do remember that Kicker had a subbass box that went back there that probably sounds as good and you can find some speakers that go up front.
Juan
Old Aug 9, 2011 | 11:29 PM
83 ZMAN's Avatar
Re: Remember the Kicker SSCTF
Dave Peterson is right on the money.
I also had a kicker CTF box in my 83 Z28 and it sounded AWESOME. The people posting the negative comments are not up to speed with these full range boxes. The imaging is excellent.
I powered the stock speakers in the dash and rear pillars with a Sony high power head unit putting out 50 watts x 4 channels. For signal to the CTF, I tapped off the rear speaker inputs, ran them into a high to low level converter (to avoid burning up the amp) then into a a small Alpine 3522 bridgeable amp. I was able to balance the sound perfectly by adjusting the gain on the signal converter.
There were no holes in the imaging whatsoever. This system was exception for rock music as it generated extremely high sound pressure levels, exceptionally low tight base with zero speaker clipping.
I never had to turn the volume up beyond 50% because the speakers were properly amplified. The best characteristic of these boxes was the mid bass they provided.
I have owned a lot of audiophile level car equipment since the early 80's and this system stands out as one of the best. The CTF box is perfect for the third generation Camaros. Take my word for it, you will not be disappointed. An awesome sounding old school system which kicks *** even by todays standards.
Old Aug 10, 2011 | 01:19 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
You chose to bring up a 10 year old thread to make your comment?
umm, alright.
Old Aug 10, 2011 | 06:16 PM
83 ZMAN's Avatar
A work acquaintance with an 85 IROC mentioned he opted not to search for a CTF box based on this post. I just wanted to set the record straight and help the next person who might be in the same situation.
If it doesn't interest you, why post a reply. Umm, alright.
Old Aug 13, 2020 | 03:49 PM
Matt Janey's Avatar
Ha, I just found this thread. I've had one of these boxes since HS. We mostly used it as a PA system for parties at the lake. I later set it up in a pinch with a 6 ohm vintage receiver and it held up for 20 yrs. Just recently a tweeter gave out. I'm replacing the tweeters and looking to use it in the back of my truck just for tailgating. Any suggestions on amp specs for this?
Ed1LE
Sep 30, 2018 09:14 AM
bjpotter
Oct 4, 2015 07:48 PM
Zell1luk
Sep 29, 2015 10:36 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
ironbmt
Sep 27, 2015 06:00 AM
