Replace head unit
Old Aug 7, 2020 | 08:22 PM
JB89TA's Avatar
Replace head unit
So my head unit isn’t putting out sound to half of the speakers and I was told this is common. I was thinking about putting in a modern head unit but didn’t know where to start. Any existing threads or how tos?
Old Aug 10, 2020 | 04:51 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Replace head unit
If you got aftermarket you'll probably want to get some new speakers too. Most aftermarket radios are made to be used with 4 OHM speakers. Your factory Rear speakers *might* be 4-OHM,... but the fronts will almost certainly be 10 OHM and not well-matched for an aftermarket head unit.
Old Oct 26, 2020 | 07:07 PM
StevenK's Avatar
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
Old Oct 26, 2020 | 07:30 PM
Kincer's Avatar
Car: 1989 Trans Am
Engine: 305 H.O. TPI
Transmission: Auto 700R4
Axle/Gears: 3.42 posi
Go to Crutchfield.com they will hook you up, they send everything you need to do a nice clean install with great directions.
evster_mcman
Car Audio
Jul 9, 2007 07:09 PM
saenz
Car Audio
Nov 30, 2006 07:49 AM
AmorgetRS
Car Audio
May 19, 2001 12:13 PM
