Anyone know the output of a Monsoon head unit??
Old Nov 7, 2006 | 09:46 PM
saenz's Avatar
Wanting to install the Monsoon head unit in my 92 T/A vert and was wondering if anyone had the output specs on the Monsoon head unit? Thanks in advance for any help you can provide.
Jesse
Old Nov 8, 2006 | 06:10 AM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Transmission: 350 Turbo
Axle/Gears: 373
They claim 500 watts
Old Nov 20, 2006 | 02:29 PM
6SPEED84Z28's Avatar
Car: 84 Z28 / 91 Trans Am
Engine: LS1 / 5.0 TPI
Transmission: T56 / 700R4
Axle/Gears: 4.09 / 2.73
500 is with the separate amplifier that is located in the rear. not sure what the head unit itself is rated at itself.
Old Nov 20, 2006 | 02:48 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
7 watts RMS X 4 at 1.0THD
Old Nov 25, 2006 | 08:58 AM
blue85305's Avatar
Car: 1984 camaro
Transmission: th 350
Axle/Gears: 3:42
whatever the fuse for the amp is, multiply that by 13.8 volts and that is the maximum possible output. for example if there is a 20 amp fuse max. output would be 276 watts. that would be a very distorted 276 watts. everybody overrates there ****, unless your buying high end audio equiptment...
Old Nov 30, 2006 | 07:49 AM
ScrapMaker's Avatar
Car: 2000 Trans Am WS6 (Black)
The monsoon headunit is nothing special... there's absolutely no reason to even consider it... it probably puts out something in the ballpark of 15 watts RMS... or possiblly as low as what 1991CamaroRslow says... but I think it's a bit higher...
the 'monsoon' headunit has absolutely nothing to do with the Monsoon soundsystem, as a whole...
sweet_87_iroc
Sep 25, 2015 10:01 PM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
Dialed_In
Aug 20, 2015 01:45 PM
ZsTransAm
Aug 11, 2015 07:30 PM
