lowering operating temperature?
Old Nov 8, 2006 | 06:05 PM
stahrman0612's Avatar
Car: 1986 Trans-Am
Engine: 305 4 bbl
Transmission: 700R4 auto
Axle/Gears: posi
I have a 1986 T/A. I changed the 195 stat to a 180 stat. I also purchased, but have not installed a hypertech cool fan switch that kicks the elec fan on at 200 instead of 220. My question is.....I talked to a mechanic who told me not to use the fan switch because it causes problems with the closed loop? or something like that and it will increase fuel consumption and cause problem with computer reading o2 sensor or something like that. Is he crazy? I've heard that these are cheap simple fixes to lower the normal operating temp. of our third gens (which was implemented by gm to lower emissions, not considering the wear on our engines and poorer performance) Can somebody please help!! Thanks!!!
Old Nov 8, 2006 | 10:05 PM
irocdan's Avatar
Car: 88 Iroc vert
Engine: 305 tpi. cts-v brakes
Transmission: Tremec T-56
i think this is in the wrong section but im running the hypertech too n it was the best thing i could have done.
Old Nov 18, 2006 | 11:18 PM
di11avou's Avatar
Car: 1988 Camaro
Engine: 305ci TBI
At the end of the summer I swapped my single fan for the dual fan setup along with a 180* t-stat and a 200* temp switch. I am VERY happy with the results. Don't worry about closed loop problems. You will still hit closed loop at those temps.
The Hypertech temp switch is way overpriced. You can get one from here for about $15. Part #609-106:
http://www.madvet.com/shop?frame=3.138.944
Yeah this is in the wrong section, but I'm sure a mod would be happy to move it.
Old Nov 18, 2006 | 11:50 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
IIRC you start to have problems with closed loop with the 160 T-stat.... You should be fine.
Old Nov 30, 2006 | 11:49 AM
irocdan's Avatar
Car: 88 Iroc vert
i think i only paid $69 for mine a few years ago
Old Nov 30, 2006 | 02:18 PM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
I think I read somewhere that many of the closed / open loop temp parameters are at 176, so above that should be ok and not mess up anything...
Old Nov 30, 2006 | 04:59 PM
Jaime-TA-84's Avatar
Car: 1984 Firebird Trans Am
Axle/Gears: 3.73 Posi
Will that $15 sensor work with an L69?
Old Nov 30, 2006 | 09:01 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Mine goes into closed loop at 150 degrees or so. Only thing you might notice is a slightly higher idle when it's right on the thermostat temp.
Old Dec 1, 2006 | 11:53 PM
di11avou's Avatar
Car: 1988 Camaro
Engine: 305ci TBI
Well if it's the single fan setup it will work fine. I'm not 100% sure on the dual fans, but I believe it will only effect the secondary fan or something like that. IIRC the primary fan is controlled by the computer.
Bubbajones_ya
Jul 6, 2024 08:32 PM
69GTOby
Apr 18, 2016 02:34 PM
Formula8r89
Sep 22, 2015 04:24 PM
Stryker412
Sep 20, 2015 06:59 PM
64goatman
Sep 9, 2015 01:09 PM
