dash
Old Mar 11, 2001 | 07:45 PM
v6-3.1's Avatar
dash
I want to put speakers in my dash area, but I do not want to put 4x6. what other size speaker can I fit ? what is the largest speaker can I fit?
Old Mar 11, 2001 | 09:00 PM
DJSexay's Avatar
thought about kickpanels ??
http://www.lachernet.com/kickpanels
mike
custom 3rd gen kickpanels at http://www.lachernet.com/kickpanels
Old Mar 11, 2001 | 09:28 PM
v6-3.1's Avatar
I dont like the loss of leg space. I only want to run 100 watts rms per speaker.
Old Mar 12, 2001 | 01:28 AM
Belker's Avatar
If you don't want to use a regular oval shaped 4x6 then you could get a 4x6 plate which has a round 4" and a tweeter (or you could make some). You might possibly be able to sqweeze a 5.25" in there but you would have to start hacking off pieces of the internal dash to get it to fit. It could be done I guess.
I would recomment kickpanel pods. This is the way to go ... but I also understand your apprehesion. Another alternative, that would be better than dash mount, is door pods. This would retain all the foot space ... but wouldn't really be any easier to accomplish than kicks.
Old Mar 12, 2001 | 11:17 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
<font face="Verdana, Arial" size="2">I only want to run 100 watts rms per speaker. </font>
That's MASSIVE overkill dude. No 4x6 on the planet will survive with anywhere near that much power. I'm running mine with a 30 watt amp running 80hz high-pass and even as loud as I can stand it, I'm not using anywhere near the full 30 watts. Bass is what needs power, and 4x6s shouldn't ever get any low frequencies sent to them.
In my IROC I've got a Kicker ZR240 running my 6.5" separates, and that amp is WAAAAAYY more power than they'll ever need. It's rated at 60x2.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Mar 12, 2001 | 09:29 PM
v6-3.1's Avatar
so what is the biggest speaker I can fit?
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
86IROC112
Nov 7, 2015 06:50 AM
Fanatic1074
Oct 2, 2015 03:47 PM
lewandom
Oct 1, 2015 08:15 AM
Eric-86sc
Sep 28, 2015 11:37 AM
