'84 Trans Am Sail Round Speaker Replacement
Old Sep 28, 2020 | 05:52 PM
Fxd99harley's Avatar
Car: 1984 Trans Am
I have the. 4 1/16" Round Speaker holes in my '84 TA 'Sails' location that I'm having an issue with.
According to Crutchfield the P152 should work. Not the case since Speaker will not even go anywhere near flush even with hole adaptor. Not much material can be removed for widening hole due to its construction.
Have read there are TA's out there with 5 1/4" or so Round holes.
My question is simply what Make and Model # for a Good speaker will work.
Mike
Old Sep 28, 2020 | 07:49 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: '84 Trans Am Sail Round Speaker Replacement
those speaker plates were for the optional "performance sound"-the standard version had sheet metal plates installed to mount 6x9s,you could obtain or recreate those plates to install 6x9s
Old Sep 28, 2020 | 08:05 PM
Car: 1984 Trans Am
Thank you for the information.
I'll look around for the original cover. I have not seen any standard covers for sale but hopefully I can locate them.
Old Sep 29, 2020 | 12:04 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I've got a pair of original 6x9" speaker mounting brackets. If you still need a pair send me a PM that includes your ZIP code for more info.
Old Sep 29, 2020 | 02:50 PM
Car: 1984 Trans Am
I PM you but not sure it went through.
Can you send front and back pics and overall dimensions so I can see if they will fit over existing cutouts?
I found a pair on EBay and wanted to see condition and price on yours also.
Thank You
Mike
Old Sep 29, 2020 | 03:07 PM
John in RI's Avatar
I wanted to check fitment,.. you have a PM !
ducatigaz
Car Audio
Aug 4, 2020 11:04 AM
IROC-ZTWENTYGR8
Oct 9, 2000 04:35 PM
