Double Din install question
Old Dec 7, 2020 | 10:21 PM
Buzzkiller's Avatar
Car: 1991 Z28 Coupe
Engine: 5.7L
Most of the articles I've read on here seem to discuss only the bezel issue. I am attempting to install a Sony XAVV10BT (6.2" Screen). Are there any console modifications needed to install a double din? The unit does not seem to want to seat at the rear of the center console. I can't be sure what needs cut, if anything before I fabricate brackets. Any help with this would be appreciated.
Old Dec 8, 2020 | 09:15 AM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Re: Double Din install question
Usually the support brace between the sides of the console needs to be cut/removed for a Double Din to fit.
Old Dec 8, 2020 | 09:33 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
I also had an issue with the ducts glued to the insides. There a bit tall/oversized for the two ducts coming from the dash. I sectioned about 1/2" from each.
Old Jul 30, 2021 | 03:43 PM
Buzzkiller's Avatar
Car: 1991 Z28 Coupe
Engine: 5.7L
Double Din install Life hack
I got it to work, custom made brackets to install the stereo and to replace the HVAC controller bracket.
Old Aug 2, 2021 | 09:56 AM
scfbody's Avatar
Car: 1983 Z28, 1991 Z28 & 1985 TA
Re: Double Din install Life hack
Where did you get the bezel?
Old Aug 5, 2021 | 12:13 AM
Buzzkiller's Avatar
Car: 1991 Z28 Coupe
Engine: 5.7L
eBay....
Old Aug 5, 2021 | 08:26 AM
scfbody's Avatar
Thanks! Looks better than the one I got.
rebel1222
Car Audio
Mar 4, 2007 07:42 PM
srdynamics1
Jan 10, 2005 10:15 PM
CraZ-28
Jun 21, 2003 08:21 PM
