Speaker trouble
Old Feb 28, 2022 | 10:38 AM
RPhillips's Avatar
Speaker trouble
Needing some advice/help on replacing the speakers in a 91 RS. I thought the factory speakers were blown but upon removing them they look in great shape. The new speakers I am installing are 3 way speakers. I took some jumper wires and hooked up the new speaker to the factory plug and the speaker turns on but isn’t very loud. I can adjust the volume all the way up and down and there is no change in how loud the speaker gets. I also notice that if I jiggle the connector the speaker cuts out/ gets static but that could be because it’s not correctly wired in. When I removed the panels there was some water from the T tops leaking but the plug for the speakers looked to be in good shape. Any body have any suggestions. Thanks!
Old Mar 1, 2022 | 09:25 AM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
Re: Speaker trouble
What are the ohm ratings of the old speakers vs the new speakers? They must be the same.
Old Mar 3, 2022 | 09:47 PM
Rockguy's Avatar
Car: 88 IROC-Z
Engine: 5.7 TPI
Re: Speaker trouble
Amplifiers.
Old Mar 6, 2022 | 08:04 AM
patriot_tech's Avatar
Re: Speaker trouble
Sounds more like the internal amp in your radio is bad. A speaker can look perfect and be blown btw. If you adjust volume and there is no change it's most likely the radio.
iroc89al3
Car Audio
Sep 24, 2012 12:19 AM
58mark
Car Audio
37
Dec 20, 2011 05:40 PM
ANDYZ28
Car Audio
41
Nov 3, 2009 11:46 PM
WaynesRS
Car Audio
Mar 27, 2002 09:49 PM
