How do i bridge this?
Old Jan 19, 2002 | 02:32 PM
1986CamaroSC's Avatar
Car: 1986 Camaro SC
i have an mtx 2300 and for briged mode it says
"for briged operation connect left(+) to mono speaker(s) postive terminal. Connect right(-) to mono speaker(s) negative terminal.
So what do i do, if i have 2 subs ina box with 2 different sets of
Old Jan 19, 2002 | 04:03 PM
espirocz's Avatar
Car: CTS-V & 89 Z28 vortech charged
Engine: LS6 & 383 charged stroker
Transmission: 6-speed & 5 speed
You can either run the amp in stereo, with positives going to pos. and negitives going to negs. OR Wire it bridged with both pos going to one terminal and both negs going to one terminal. Depending on ohm resistance of speakers the ohm load should drop in half by wiring in parallel. if 4 ohm speakers your amp will see 2 ohms, so make sure your amp can handle 2 ohm load in bridged mode.
Old Jan 21, 2002 | 07:44 AM
Allan's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
Usually, now not all subs are the same, but usually, I see this on my amp:
+ - + - I would use the outer two + and -. Mine has a switch to go from mono to stereo as well.
Old Jan 21, 2002 | 05:53 PM
nagga's Avatar
dont know how to better put it than this
Old Jan 21, 2002 | 06:45 PM
Allan's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
If your subs are 8 ohm, it would produce a 4 ohm load. Just noting a correction there. Well said otherwise!
Old Jan 21, 2002 | 11:51 PM
nagga's Avatar
oops lol typo
CD MaroMan 91
Car Audio
Sep 1, 2001 12:27 PM
89Firebird Formula350
Car Audio
Aug 30, 2001 06:41 AM
TrueBlue91RS
Car Audio
Aug 18, 2001 11:58 PM
TrueBlue91RS
Car Audio
Aug 14, 2001 07:30 AM
Tom 400 CFI
Car Audio
Apr 29, 2001 01:48 PM
