Advice on UQ7 Performance Sound system
Old Jul 8, 2023 | 08:38 AM
88BLKTransAmGTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 L98
Axle/Gears: 3.77
I had my ut4 rebuilt. My gain switch lights up when pressed. Steering wheel controls work. I have the oem speaker boxes with 5 inch sub just not in. No amp though. (Currently has 6x9s) How can I wire an aftermarket amp to the gain control and the head unit? switch on the dash? Also looking at after market subs in back hatch. What would be easier?
Old Oct 8, 2023 | 05:32 PM
Engine: 5.7 L98
Axle/Gears: 3.77
Re: Advice on UQ7 Performance Sound system
I wanted to share the subwoofers I ended up finding that fit in the boxes. Couldn't find anything to fit the original mounting holes. The holes of these boxes were 4"
I went with the Dayton 4 1/2 Cf120s carbon fiber
-Overall Outside Diameter 4-7/8"
Overall Depth 2-5/16"
Baffle Cutout Diameter 4" Mounting Hole Diameter
Power Handling (RMS) 30 watts
Power Handling (max) 60 watts Continuous Program Power -- Impedance 4 ohms
Sensitivity 89.1 dB 2.83V/1m
Frequency Response 50 - 15 000 Hz Voice Coil
Old Oct 8, 2023 | 06:12 PM
Drgnbld's Avatar
Car: 89 GTA
Transmission: auto
Axle/Gears: 3.23 BW 9 bolt
How do they sound?
Old Oct 21, 2023 | 01:41 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
@88BLKTransAmGTA :
Can you post a picture of the radio installed in your ride ?
Old Oct 23, 2023 | 08:10 PM
Engine: 5.7 L98
Axle/Gears: 3.77
@88BLKTransAmGTA :
valicswarrior
Car Audio
Mar 8, 2016 07:24 PM
SDalt404
Interior Parts Wanted
Feb 10, 2010 06:54 PM
briwar454
Car Audio
Jul 15, 2008 12:46 PM
REDRIDER89125
Car Audio
Feb 24, 2003 10:43 PM
