Gain Slide Switch
Old Nov 29, 2015 | 09:58 AM
valicswarrior's Avatar
Car: 1985 Firebird S/E
Engine: SBC 350, mild cam Vortec heads
Transmission: Rebuilt 700R4 vette servo+shift kit
Gain Slide Switch
I have a 1985 firebird S/E. Stock it had the Bose sound system (long gone) given it had the premium sound package on the dash there is a little slide switch labeled gain. Is there way to wire this to say the Remote wire for my car amp so that I could turn my amp on/off with a factory switch when I want or don't want subs kicking? If so how do I wire it up? I can take someone photos of the wiring for the switch tomorrow.
Old Nov 30, 2015 | 09:12 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Gain Slide Switch
That gain switch is from the UQ7 Sound System.It's actually for the Amp and the Subs.
Old Dec 1, 2015 | 06:16 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Remove the switch from the dash and check the pins yourself. Find the two pins that make contact when switch is depressed and opens when switch is released. Use this as the switchable ground trigger to a suitable relay to your amp.
Old Dec 1, 2015 | 09:23 AM
-srs-'s Avatar
Car: 1991 Z28 Vert
Don't skip over the part about only using it to trigger a relay. VERY important if you want the switch to live.
Old Dec 1, 2015 | 03:50 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Don't most amps receive a 'power on' signal from the head unit? I'm not aware of any that just sit there idling 24/7.
Just wire this lead thru the switch.
Old Dec 1, 2015 | 03:57 PM
That's what I am referring to the "remote power" typically a blue wire from the head unit to the amp. I am not talking about the heavy gauge power from batt to amp.
Old Dec 1, 2015 | 04:08 PM
-srs-'s Avatar
Car: 1991 Z28 Vert
Without knowing how much current the switch is rated for and how much current is required to trigger the amp remote, you're gambling that it'll work. A mini SPDT 12v relay is a couple bucks worth of good insurance.
Old Dec 2, 2015 | 06:43 AM
naf's Avatar
naf
Based on the wire size i'm certain we're safe without the relay.
Old Dec 15, 2015 | 06:10 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Oh I misunderstood. I thought you were trying to supply power to an amp. My guess is the little wire that turns the amp "on" is very low current and will be safe run through the gain switch. Just double check the amperage first.
Old Feb 21, 2016 | 12:20 PM
jake87GTA's Avatar
As long as its a physical switch and not a dimmer there shouldnt be an issue.
Let me know how it goes ive been trying to think of a dimmer application for the gain slider. Interior colorlow lights maybe
Old Mar 8, 2016 | 07:24 PM
So I tried to test this setup out and I had no power on my head unit today. Gotta take some dash apart and figure out if I disconnected something or see if head unit power is somehow running through that factory switch.
matt0626
May 4, 2016 11:55 PM
Drone358
Jan 16, 2016 07:48 AM
valicswarrior
Nov 22, 2015 07:53 AM
Slash
Nov 17, 2015 11:54 AM
90formulaVortec
Nov 9, 2015 05:07 PM
