No stereo in my car but have bose amp speakers
Old Jul 24, 2023 | 10:19 PM
Powderburn's Avatar
Car: 1990 IROC 1LE
Engine: 5.7
Axle/Gears: 410 spool
I am wondering if i need a delco bose unit or can i use aftermarket
Old Jul 28, 2023 | 01:30 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: No stereo in my car but have bose amp speakers
The BOSE radio needs to use the BOSE AMP/Speakers to work properly.
You can't just install an aftermarket radio and then connect it to the factory BOSE Speakers/AMPs/Wiring.
You can use an aftermarket head unit connected to the BOSE Speakers/AMPs/Wiring,.... but in order to do so you will need to install a "signal converter".
BOSE speakers are 2 OHM speakers, and most aftermarket speakers are 4OHM.
Old Jul 30, 2023 | 11:36 AM
Nutro's Avatar
Following as I am about to do all of this. I am removing the Bose setup from my 88 and will just wire in new speakers using an aftermarket head unit.
Max Dunlap
Car Audio
May 30, 2005 11:00 AM
BLOWN25TH
Car Audio
Nov 22, 2004 03:01 PM
FastElectrics
Car Audio
Jan 1, 2004 11:14 AM
jdrafke
Car Audio
Dec 17, 2003 03:12 AM
bad_ta_05
Car Audio
Dec 12, 2002 09:52 PM
